Wheel spacer help
Old Aug 12, 2023 | 12:02 PM
Woodrow Miller's Avatar
Woodrow Miller
Default Wheel spacer help
Maybe dumb question but 2015 rg wheel spacer on left is 1” wide and left is 1/4” wide? Thank u
Old Aug 12, 2023 | 12:28 PM
MotoJockey's Avatar
MotoJockey
Front wheel? Rear wheel? ABS? Non ABS? Check these diagrams below.......
Front Wheel
https://www.harley-davidson.com/us/e...dd5df5c44dee/y
Rear Wheel
https://www.harley-davidson.com/us/e...81069c05d0fe/y
Old Aug 12, 2023 | 12:33 PM
Woodrow Miller
Front Wheel
Rear Wheel
rear non abs. Sorry about that
Old Aug 12, 2023 | 12:42 PM
MotoJockey's Avatar
MotoJockey
Did the diagrams help?
A Non ABS bike has a spacer on the right side rear to take up the space of where the ABS pickup sensor WOULD be, if it were there. So yes, two different sized spacers on the rear wheel.......
Old Aug 12, 2023 | 12:44 PM
Woodrow Miller
I know that I’m trying to verify the sizes I have that they are infancy 1” right side 1/4” left side.
Old Aug 12, 2023 | 12:52 PM
MotoJockey's Avatar
MotoJockey
Sir, if you look at the Rear Wheel diagram, it clearly shows that item #6, Spacer, is thinner AND cheaper than Item #15, Non ABS Spacer. That should have answered all your questions and concerns. Do you own the FSM for your bike? The answer is in there also.
Old Aug 12, 2023 | 12:53 PM
Musician's Avatar
Musician
Just did a new rear tire and bearings on my FLHT. Those spacers are correct. If you are going to work on your bike, I can't stress enough how much you need to get the factory manual.
Old Aug 12, 2023 | 12:59 PM
Woodrow Miller
Default Spacers
I agree I should and my spacers got mixed up with others accidentally so I see in the pics the difference but I have some that r 1 1/4” and 1” and 3/4 and 1” and then I have 1/4,3/8. And 1/2” so that’s why I was asking for actual sizes which I can’t seemed to find. The manual doesn’t give that info.
Old Aug 12, 2023 | 01:08 PM
GalvTexGuy's Avatar
GalvTexGuy
It says these are “factory replacement” spacers.
https://www.lowbrowcustoms.com/produ...idson-41242-08
https://www.lowbrowcustoms.com/produ...davidson-11848
Old Aug 12, 2023 | 01:26 PM
Woodrow Miller
Default Spacers
Thank you very much
Maddog312
Oct 5, 2018 09:54 PM
97fastta
Touring Parts
Sep 23, 2015 10:10 PM
FLHXI103
Wheels/Tires
Aug 7, 2013 09:58 PM
SpiderPig
Touring Parts
Jun 29, 2013 12:21 AM
dwdet10
Feb 3, 2010 06:08 AM
