Small leak on 08 street glide
Old Sep 7, 2023 | 04:35 PM
Dekay's Avatar
Dekay
6th Gear
Default Small leak on 08 street glide
Yo,
I recently spotted a small leak under my bike. I recently changed my engine, transmission and oil filter oil about a month ago with no issues. I’m just trying to figure out what and how to fix it with out taking it into Harley Davidson. Here are a few pics. I originally thought it was come from the bolt I circled in red but after my ocd kicked in… I’m almost sure it coming from the center where I’m assuming the gasket is. I’m not a gear head but I’m into learning. Thank you in advance.
08 street glide
Old Sep 7, 2023 | 04:39 PM
Rounders's Avatar
Rounders
. I’m just trying to figure out what and how to fix it b62c152355842b385edb5.jpeg[/img][/QUOTE]
Brake clean, until it gets worse.
Old Sep 7, 2023 | 05:39 PM
Inop's Avatar
Inop
Clean it really good and throw some baby powder on it. That way you can pinpoint where it’s coming from
Old Sep 7, 2023 | 05:46 PM
Ohio HD's Avatar
Ohio HD
Did you replace all of the drain plug o-rings?
Old Sep 7, 2023 | 06:22 PM
Max Headflow's Avatar
Max Headflow
If it's not from the oil change, it's likely from the alternator wire exit in the primary case. You can also look at the crank sensor but they typically don't leak from there..
Old Sep 7, 2023 | 08:28 PM
tomryan's Avatar
tomryan
My 08 developed a leak from the starter. I tried third party starters. They all leaked. Bought oem and didn’t have any further issues.
Old Sep 7, 2023 | 10:15 PM
Dekay's Avatar
Dekay
6th Gear
Yes. I bought the kit from HD
Old Sep 7, 2023 | 10:31 PM
Rounders's Avatar
Rounders
earlier this year, I got the kit, cause they were running a sale for fathers day, and it was cheaper to get kit the parts guy said. If that tells you anything. I often reuse the orings too, but always have extras on hand. But the kit is gouging I am pretty sure, cause guys can't remember 1 filter, 1 oring, and 4 quarts.
Old Sep 7, 2023 | 10:40 PM
Max Headflow
Wonder if the tranny vent is plugged.. Some insects like to crawl in the hose and make a nest.. Plugged tranny vent will allow pressure to build in the primary..
Old Sep 7, 2023 | 10:41 PM
springers4ever's Avatar
springers4ever
Cool Residue
Originally Posted by Dekay
Yo,
08 street glide
Looks like residue from the oil filter being taken off ...the oil that falls down the front motor mount ..and is hard to clean out ...most will drip for a while till dirt build up enough to stop it !!
Spray Simple Green all around and let soak just a few minutes ...rinse and recheck ...
Good Luck ..!! Yo !!!
