Stator problem
Old Sep 17, 2023 | 05:44 PM
JordanJim's Avatar
JordanJim
Default Stator problem
Iv got a 2011 ultra limited. I think stator has gone bad. Iv read a lot of post on here about the OHm. And I'm pretty sure mine is bad but I hope someone can clear it up for me. When I ohm to ground all three legs were good. There were 0 ohms to ground and then I ohm to each leg and 1to 2 was .1 and 1 to 3 was .3 and 2 to 3 was .5. So I as I understand that this means I have a bad stator. And thanks for the help.
Old Sep 17, 2023 | 06:38 PM
1957buick's Avatar
1957buick
JP CYCLES has a U-tube on how to check the stator
Old Sep 17, 2023 | 06:49 PM
WP50's Avatar
WP50
It's been abit for me to recall.
Ck this out for some good info
https://www.hdforums.com/forum/elect...sting-2-a.html
Good luck WP
Old Sep 17, 2023 | 07:39 PM
Rounders's Avatar
Rounders
What else is it doing?
does it go to to 14.4 volts DC when reved up?
You can check that you are getting around 80 volts or so AC at connector from stator to volt reg. Depending on year this can be pain. But you already got connector apart.
Around 20 volts ac per 1k rpm, just rev it up until you see 80 or 100 volts ac.
Old Sep 17, 2023 | 07:52 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Other information and testing is here:
http://cycleelectricinc.com/Diegnosi...lternators.htm
Old Sep 18, 2023 | 01:21 AM
xcbullet's Avatar
xcbullet
If you open the primary you will be able to tell by the smell.
Old Sep 18, 2023 | 02:18 AM
Jackie Paper's Avatar
Jackie Paper
Yes, it's bad. What is your DC reading at battery with engine running at 2000 or so RPM?
Reason I ask is just wanted to make sure your ohm meter is good or your doing it correctly unhooked?
Assume you're chasing an issue.
Make sure battery is good before doing anything. Then DC voltage at 2000 (13.5-14.9). Then stator unhooked and ohm readings, and then stator checks to frame ground.
PS.. welcome. And only as a suggestion, make your next new post over in the new member welcome area to say hello.
Old Sep 22, 2023 | 06:49 PM
HedleyLamarr's Avatar
HedleyLamarr
I just swapped out mine on my 2012 FLHP. So to save you some time, Lowbrow Customs has the best price on the Cycle Electric one I found
reelheavy
Jun 24, 2022 06:12 PM
glcash
Touring Parts
Dec 2, 2020 03:54 PM
RedRick
Jul 30, 2020 11:43 AM
Tinmanpope
Mar 14, 2017 08:15 PM
RANVIS
Sep 9, 2012 12:31 AM
