Speedo sensor
Old Sep 28, 2023 | 05:00 PM
BrownStone's Avatar
BrownStone
Stage II
Default Speedo sensor
2006 roadking classic. Speedo went out. Replaced the sensor but to no avail. I also tried resetting by holding key fob. Any ideas on what to try next . Thanks
Old Sep 28, 2023 | 05:39 PM
Spartanden's Avatar
Spartanden
Can't help here, but.....
I tell a lot of new comers to the forum to get: Factory Service manual and the Parts manual. Take to an office supply store and have them put a spiral binder in place of the glued binder. That will let the manuals lay flat on your bench. Get a three ring binder and record all your maintenance, repairs, accessories, etc. This will be a great reminder of what was done when. And great material to pass along to the new owner should you sell and upgrade. Also know how large your fuel tank is, a rough idea of your range per tank, and record your fuel usage. I have an app called Simply Auto that I record all my fuel used. I use the odometer and use the fuel gage as reference only. I reset the odometer to zero on fill ups, and I know I can safely get 200 miles on a tank on around town riding, and upwards of 230+ on trips.
Old Sep 29, 2023 | 05:52 AM
kojak's Avatar
kojak
there are a lot of threads on this, fairly common in those model years. Could be a variety of reasons. When you say your speedometer went out, do the turn signals or the odometer work? Did you do any work recently to your bike?
Old Sep 29, 2023 | 06:39 AM
BrownStone's Avatar
BrownStone
Stage II
Yes everything works.
Old Sep 29, 2023 | 04:15 PM
kojak's Avatar
kojak
Okay, did you pull any codes?
NickSchoff
EVO
Sep 19, 2023 11:39 AM
19JMan70
Apr 11, 2014 06:03 PM
toodawgs
Jun 12, 2011 01:32 PM
hammon
Jun 9, 2008 06:44 PM
emeraldbiker
Aug 14, 2006 10:32 AM
