push button gas door wont open correctly.
Old Oct 7, 2023 | 01:42 PM
trigger1911's Avatar
trigger1911
Everyone needs an Uncle Larry! Thanks buddy
Old Oct 7, 2023 | 01:50 PM
Rounders's Avatar
Rounders
I was in Alaska and the harley locking one started screwing up. I was worried it wouldn't open, so I took it odd. I haven't had a button in over a decade. Cover just sits there.
Old Oct 8, 2023 | 08:14 AM
Ssitruc's Avatar
Ssitruc
When mine gets where it wants to catch instead of open or won't release, I take a little dab of lithium grease and smear a thin coat on the plastic piece that slide inside the other (#2 in the diagram above), including the catch notch. Cured it every time.
Old Oct 8, 2023 | 08:52 AM
trigger1911
The problem with the one I have is that the sliding piece is metal and I just ground off the nose
Old Oct 8, 2023 | 09:10 AM
Uncle Larry's Avatar
Uncle Larry
If that doesn't work you might try one of these :>)
Old Oct 8, 2023 | 09:12 AM
trigger1911
That wont work....its not a 10mm!
Old Oct 8, 2023 | 09:13 AM
bradsULtd's Avatar
bradsULtd
You can also rotate #2 (after loosening the nut a little) slightly, trying to center it and lithium grease above helps also...
Old Oct 8, 2023 | 09:25 AM
dasmotorrad's Avatar
dasmotorrad
That's happened to me on 3 of my touring bikes and I just filed the tip down a little and never had another problem with it.
Old Oct 8, 2023 | 11:27 AM
Taxgod4u's Avatar
Taxgod4u
There is adjustment in the hindge/spring screw holes too. Just loosen and slide lid away from latch. Less destructive...
Old Oct 8, 2023 | 01:55 PM
Ghost_13's Avatar
Ghost_13
Originally Posted by trigger1911
Problem solved! The nose of the push button unit that goes inside the factory dash to actually lock the door was a little too long. No matter how hard you pushed the button it would not retract far enough and was still locked. I ground off the nose of the part and now it works with a little push on the bottom of the door but it will not open by simply pushing the button. No more gas station visits to find out I dont have my keys with me!
Another workaround - install a couple of those (small) glue / press on rubber feet / pads
accomplishes the same
Ghost
