No brake lights
Old Nov 14, 2023 | 01:13 PM
Uncleford's Avatar
Uncleford
Default No brake lights
I have a 2011 RGC. Everything works except the brake lights. All fuses are good and I swapped relays and still nothing. I disconnected the harness to the tail lights ( I have aftermarket leds) and I’m not getting any power to the brake wire part.
I read through the forums and found a couple of threads like my issue but still couldn’t figure it out. Anyone help? Thanks!
Old Nov 14, 2023 | 01:44 PM
GalvTexGuy's Avatar
GalvTexGuy
Did you inspect the wiring where it runs in the rear fender to the light?
Old Nov 14, 2023 | 02:16 PM
eighteight's Avatar
eighteight
Does the brake lite work with the front lever and just NOT the rear pedal ?
Check for power incoming to the hydraulic switch plumbed into the rear brake line
If power is present , depress the pedal and check the OUTGOING lead
see item 32 below
Old Nov 14, 2023 | 03:01 PM
Vernal's Avatar
Vernal
@Uncleford
Welcome to the Forum from Utah!
There is a connector under the seat that goes to the taillights. Do you have power there for the Brake light?
The wires leave that connector, then go under the rear fender before coming up to the module. Like GalvTexGuy was saying, under the fender is a common place for the wires to get damaged.
Old Nov 14, 2023 | 03:36 PM
Uncleford's Avatar
Uncleford
I have a connection in the fuse box area. If it’s the same one your talking about then, no I don’t have power there
Old Nov 14, 2023 | 03:38 PM
Uncleford's Avatar
Uncleford
The front brake doesn’t work nor does the rear for brake lights
Old Nov 14, 2023 | 03:42 PM
Uncleford's Avatar
Uncleford
And yes, both wires on the front brake switch have power to them with key on. It’s a new switch I haven’t soldered in yet. It’s still bare wires tied together while I troubleshoot
Old Nov 14, 2023 | 04:47 PM
Vernal's Avatar
Vernal
Do you have ABS?
Old Nov 14, 2023 | 04:49 PM
Buelligan666's Avatar
Buelligan666
Connection should be under the seat. Behind the battery. Did you check the fuses for continuity with an ohm meter? Visual inspection doesn't always catch a bad fuse.
Old Nov 14, 2023 | 04:54 PM
07UltraGuy's Avatar
07UltraGuy
It may sound like bullshit, but don’t rely on your test results at the lamp socket… unplug the lamp socket from the harness and check for power TO the lamp socket.
The internal contacts in the socket are small wires, and they corrode creating an open (or excessive resistance), which prevents the bulb from illuminating.
I fixed this for a buddy by replacing his lamp socket.
