I got Custom Dynamics Tribar on my 2022 ROak King Special rear fender. For some reason today I noticed it stay lit all the time even when I push the brake. What is strange is that my turn signals blink when I hit the brake just not tribar light.
I tried turning plugs but when I do it will turn off turn signals completely or just keep tribar lit.
Do you have some kind of blink module? The CD Probeam tribar does not blink by default.
I do have tripple play module in fact. So are you saying with this module this Tribar shouldnt blink? That would be bummer as why would I spend $200 to have only running light that doesnt blink already? Is there any setting I should check on blinker module to correct it? Can you please provide more info
The factory tri-bar is running light only
The CD tri-bar is running and brake, it does not blink, strobe, flash or whatever you want to call it.
well this is incorrect if you have tripple play module tribar strobe same as blinkers when you hit the brake. Check this video at about 50 sec mark as he demonstrate it.
