Lowering brackets on 13” Legend shocks
Old Dec 29, 2023 | 09:02 AM
NoRegerts's Avatar
NoRegerts
You're running a tough combo of taller shocks and wider slip-ons. When I had 13" Ohlins and S&S 4.5", similar to what you're running, the axle bolt was extremely close to the muffler. I loosened the hanger and the slip joint at the front, to try to give myself as much room as possible, then tightened everything back down. In the time I had that set-up, I did not have the axle hit the muffler, but it's was close.
Old Dec 29, 2023 | 11:09 AM
Burbur2's Avatar
Burbur2
Good tips guys I might try that approach.
Old Dec 29, 2023 | 07:08 PM
kojak's Avatar
kojak
Originally Posted by Burbur2
I would say 370lbs combined weight so my shock is quite extended. I had to adjust preload quite a bit to get comfortable ride I have seen one similar report from other team member here with same issue with KW mufflers. Mine spring is pretty compressed on my shock. If I release spring tension yes I gain a lot of clearance.
As far as loosening header at the heads to adjust this wouldn't that be prone to air leak since whole header would be at slight angle? I feel my issue is with shocks as everything else is stock beside mufflers. I have to say I am even considering going back to 12” shock but I hate the idea as 3” of travel is nice.
We're around 335 combined. I would go to 4" mufflers before I would go to 12" shocks or lowering blocks.
Old Dec 29, 2023 | 08:55 PM
Burbur2's Avatar
Burbur2
I have to admit that crossed my mind as well. Love my KW but I would rather sacrifice this than comfort of 3” shock travel
Old Dec 30, 2023 | 06:57 AM
RKZen's Avatar
RKZen
There are great name-brand 12" shocks with 3" or more of travel.
Old Dec 30, 2023 | 07:31 AM
Burbur2's Avatar
Burbur2
I know Ohlins has 3” travel with 12” shock but not aware of others. Also heard Legends is better than Ohlins but I guess this is subjective
Old Dec 30, 2023 | 08:51 AM
Uncle Larry's Avatar
Uncle Larry
You may have already read this ( old news ) but I remember reading threads on lowering blocks causing damage ( cracking / breaking ) the swing arm ... Of course this was on older scooters ...Just thought it might be worth mentioning
Old Dec 30, 2023 | 10:43 AM
RKZen's Avatar
RKZen
Yes shocks comfort is subjective. Besides Ohlins, Progressive, ProAction, and someone in the Sportster forum mentioned Bitubo have 12" shocks with around a 3" travel.
As far as Legends, I'm not sure they carry a 12" shock with 3" of travel, but someone can confirm.
Old Dec 30, 2023 | 11:37 AM
Burbur2's Avatar
Burbur2
Legends with 12” shock has 2” travel for sure as I checked that before spending my $$$
Old Dec 30, 2023 | 12:49 PM
harpwrench's Avatar
harpwrench
On both my bikes I used a ball pein hammer to make clearance like factory mufflers have.
