Question about torque specifications
Old Aug 27, 2007 | 02:52 PM
fotoflojoe's Avatar
fotoflojoe
Default Question about torque specifications
That is, nuts 'n bolts torque, not rear wheel torque. Apologies if this post is in the wrong forum.
Bought an '06 RK last month, first "accessory" that I got was a service manual. One thing confuses me though; Pretty much all torque specs are given as ranges. 31-45 in/lbs., 20-30 ft./lbs., etc. These ranges seem to be pretty wide as well. This kind of puzzles me, every other service manual that I've ever seen (GM, Volkswagen, Mercedes, BMW auto) have always given an exact amount that a bolt should be torqued to. That said, I'm not sure how to deal with a range. Do I tighten to the lower end? To the upper end? Somewhere in the middle? I searched the forums and the service manual itself, didn't find anything that addresses this.
Anyone have any insight?
Thanks
-Joe
Old Aug 27, 2007 | 02:58 PM
petemac's Avatar
petemac
Default RE: Question about torque specifications
I asked this same question a year ago. The general consensus was to shoot for the middle and better off going low if you have any concerns. Has worked for me.
Old Aug 27, 2007 | 03:36 PM
fotoflojoe's Avatar
fotoflojoe
Yeah, the "voice of common sense" in my head was leading me to the same conclusion.
Thanks!
Old Aug 28, 2007 | 12:59 AM
glens's Avatar
glens
The midpoint is the target and the extremities are the allowable deviation from it.
Old Aug 28, 2007 | 03:03 AM
Drelkor's Avatar
Drelkor
In general, I go towards the lower setting. When I reach that setting, if it doesn't feel sufficiently tight to me, I go to the middle setting. If that still feels loose, I go to the top, but no more. Normally I never have to go past the middle, so the middle is usually always the "good enough" setting.
Drel
Old Aug 28, 2007 | 03:29 AM
SoCal_Pappy's Avatar
SoCal_Pappy
If it's in the middle range all is good!!!
Old Aug 28, 2007 | 04:55 AM
PapaTravis's Avatar
PapaTravis
I would say it might depend on what you are torquing down. For the oil drain plug, I say the lower end, but for the primary drain I say the higher end. I tried the lower setting for the primary, it leaked. Went to middle ground, still leaked. Went to the top, no leak, so, depending on the specific application, I say it depends. LOL Doubt this helped any, but that is how I see it.
Old Aug 28, 2007 | 06:31 AM
jakedog's Avatar
jakedog
I was always told "Everything in moderation". So I go with the middle of the range.
Old Aug 28, 2007 | 07:36 AM
MNPGRider's Avatar
MNPGRider
One of the things I noticed immediately when I started installing accessories on my '06, was the extremely high (tight) torque on any factory fastener I had to loosen, whether it be the little screws holding on the fairing wings, to the bolts holding on the saddlebag rails. I had to put a wrench on the shaft of my star driver to get enough leverage to loosen some of the star bolts.
Old Aug 28, 2007 | 08:57 AM
Harleypingman's Avatar
Harleypingman
The lower value is the minimum at which the fastener will not loosen by itself; the higher value is the maximum before the fastener will break/strip from tightening--I probably haven't expressed this in "engineer-speak", but that's the gist ofwhat my degreed mechanical engineer motorhead friend told me about a year ago--so, as others have said, go for the mid-range of the min and max values.
