Solid Handle Bar Bushings
Old Jan 6, 2024 | 08:40 AM
Mongo1958's Avatar
Mongo1958
Default Solid Handle Bar Bushings
Hey Y'all,
I have been considering Installing Solid Handle Bar Bushings to my 2009 FLHTCU Ultra Classic.
I did a search and the solid bushings seem to get installed when Apes are installed.
My bars are stock.
To those that have solid bushings on their Baggers, please give your opinion on how well, or how bad they have affected your ride.
Thanks!
OOPS, Moderators, please move my post to to the proper section. Thanks
Old Jan 6, 2024 | 08:42 PM
nocoast's Avatar
nocoast
I put 14” west coast Tbars on my 15 RGS, when I did I put poly bushings in. I think the Tbars were slightly tweaked from the factory because I would get some twisting in the bars at full lock. It didn’t really affect riding but moving the bike at low speeds I’d notice it. So I switched to solid bushings. Got rid of all twisting. Vibration is very minimal. But if I were you, I’d try polyurethane bushings first.
Old Jan 6, 2024 | 09:48 PM
Cornpipe's Avatar
Cornpipe
Veteran: Reserves
I run solids in two of my bikes and polys in the 3rd. I don't feel any difference from any of them. Out of the 3 bikes the 2 with solids have 16" apes on one and 10" t-bars on the other. The poly bike has stock bars.
Old Jan 6, 2024 | 10:35 PM
Mongo1958's Avatar
Mongo1958
I have Poly bushings installed now, replaced the old rubber bushing about 3 or 4 years ago.
Old Jan 6, 2024 | 10:41 PM
Mongo1958's Avatar
Mongo1958
I'll keep the polly bushings in for now or until the wobble in the bars gets real wonky. Right now it's tolerable. I do like the idea of solids though. All my other bikes (metric) were bolted onto the triple tree. I am not sure if the Goldwing had rubber mounted handle bars though.
Old Jan 7, 2024 | 09:45 AM
r8r_4_life's Avatar
r8r_4_life
I just recently changed stock bars for some KST 14", replaced clamp with a KST one, and bushings to poly. Although it does seem more solid, there is still some flex. I'd assume it's because of the height of the bars. On my previous bike, I did not change out the stock bushings and had 12" Wild1's. There seems to be a lot more flex with the factory bushings.
Old Jan 7, 2024 | 09:31 PM
Jshopes's Avatar
Jshopes
ive had polys on my current 10s and my prior 16s and ive never run solid bushings, never felt the need to. i feel the poly bushings are a good setup, neither bars flexed.
Old Jan 8, 2024 | 08:04 AM
Rob Harper's Avatar
Rob Harper
I have poly bushings and beach bars on my Road King. Much improved vs worn out stock bushings.
Old Jan 8, 2024 | 10:36 AM
Architect's Avatar
Architect
2009, do you have the two piece top riser clamp? If so a $20 one piece clamp from J&P or the like might fix your issue, good luck.
Old Jan 8, 2024 | 11:05 AM
Mongo1958's Avatar
Mongo1958
Yes, I have the 2 piece clamp. Single piece? Hmm... Thanks, I'll look into it.
EDIT, No. I have the single piece.
