I found a set of 2021 RoadGlide Special gauges on forum and would like to know if they should swap right out with my 2019 RoadGlide gauges? They look identical but not sure if anything changes electronically between those years.
yes, they'll fit. but, as mentioned, you will get the vinerr code unless you have the gauge flashed. i've also heard (but can neither confirm nor deny) that even though the mileage is stored in the ecm, whichever had the highest mileage, gauge or ecm, it would keep the highest number.
