Changing out a new radio unit/security
Old Mar 17, 2024 | 02:46 PM
Bearhead's Avatar
Bearhead
Stage IV
Default Changing out a new radio unit/security
I’m sure it’s out there somewhere, but I got a lot questions about security and harley
2013 Electra ultra limited
1. the Harmon unit plays works fine except all I have in an orange light for the screen with no words, I have mastered the art of finding the display brightness with no screen. When I mash on the controls up for and down I can see the screen for a second before it goes blank. I’ve already pulled the unit out and bent the pins. No fix. Anyone know a resolve?
2. If I replace the unit with an jvc or something how does that affect the security? I only have one fob and am super paranoid about all that comes with losing it and not being able to start the bike. Do I lose the security? And ability to put in the pin? I’m not worried about the cb portion or radio the wife and I have Bluetooth helmets.
thanks for any info
I’m sure there is 100 typos
Old Mar 17, 2024 | 03:29 PM
Buelligan666's Avatar
Buelligan666
Radio has nothing to do with the security. That's part of the TSSM (turn signal security module). There used to be a company that repaired those older radios. If you don't use CB I'd replace it with a good water proof (not marine) unit.
Old Mar 17, 2024 | 04:00 PM
Bearhead's Avatar
Bearhead
Stage IV
i assume with a different unit I wouldn’t be able to see the digits I’m entering.
Old Mar 17, 2024 | 04:28 PM
14GuineaPig's Avatar
14GuineaPig
The instructions for disarming the security system, without the fob, are in the owners manual.
99466-13_998726_en_US - 2013 HARLEY-DAVIDSON® OWNER'S MANUAL: TOURING MODELS | Harley-Davidson SIP
Old Mar 17, 2024 | 04:53 PM
Buelligan666
Security bypass digits? Those digits should come up in the odometer.
Old Mar 17, 2024 | 04:57 PM
Bearhead's Avatar
Bearhead
Stage IV
ohhhh that makes total sense awesome! Now I gotta figure out what those numbers are
Old Mar 17, 2024 | 05:06 PM
Mongo1958's Avatar
Mongo1958
thanks for any info
Iron cross will fix it or you can exchange it.
http://ironcrossaudio.com
Old Mar 17, 2024 | 05:09 PM
smitty901's Avatar
smitty901
thanks for any info
Iron cross will fix it with ease. Common failure. Most often connection have come lose They can also update it and fix other issues. add features.
http://ironcrossaudio.com/
Old Mar 17, 2024 | 05:17 PM
Mongo1958's Avatar
Mongo1958
PIN Rest
https://www.hdforums.com/how-tos/a/h...-system-413988
Old Mar 17, 2024 | 05:20 PM
Bearhead's Avatar
Bearhead
Stage IV
Ya ill send them it eventually, bike sat in a barn for 4 years I'm sure there is some corrosion.
I just ran out to the garage and tested it the bypass with my fob and found the code, so a big sigh of relief. I was under the impression to input the codes you need the Harmon screen. But makes total sense it’s thru the odometer. Now I just need my other fob to magically appear.
Thanks a ton guys.
laman22
Audio Systems
Jun 10, 2019 09:10 AM
HEYENG
Mar 17, 2019 07:37 PM
fxstbharley2008
2014-2024 Touring Models
33
Jun 1, 2017 10:48 AM
spider_flh_00
Jun 6, 2010 04:09 AM
AZ HARLEY
Feb 26, 2008 08:39 PM
