Greasing wear points?
Yearly, (or if I happen to have it apart for some other reason), I remove the shift levers and apply grease to the portion of the pivot shaft that I can expose by working it from both directions.
I also have a needle-like tip on my grease gun, which works to get a bit of grease inside the shaft hole on the primary case when the shifter linkage shaft is "pushed in" (towards the engine case).
Then I work the linkage in both directions to try to maximize the amount of grease that stays inside the hole.
This approach, in combination with sufficient pressure on the shaft before tightening the shift lever, has made my shifter vibration and rattle-free.
I've seen some have tapped a hole on the leading edge of their primary case & installed a grease (zirc) fitting.
It's a great idea and I've even considered doing it myself, but I forgot about doing it both times I had the inner primary off the bike.
Part # 62142. Greese able shift rod. $110 bucks.
Harley's use to have greese fitting on the shift rod and the steering neck back in the late eighties, early ninties. Another cost cutting move by the factory eliminated them.
I use whatever grease happens to be in the gun for an application like this.
Since the shaft isn't even making a full rotation under normal use and it isn't a high-speed or high-temp environment, nearly any grease that is thick enough to get into the shaft and not run back out will work just fine.
If you really want to get the entire shaft lubricated (who doesn't want that, right?!), then you can do a garage hack by removing the shift arm(s) and pushing the shaft as far "IN" (towards the engine) as possible.
Then you'll see a short "nub" of the shaft still protruding out on the face.
Get something like an old spark plug boot and shove it over that nub, then force grease into the top of the boot.
It'll take a bit of effort, but keep at it & you'll eventually see grease popping out the backside of the inner primary around the shift shaft.
Then put it back together, clean up the mess, and ride it for another year.
I do the same type of thing with the jiffy stand every once in a while.
