Battery drain
Old Apr 8, 2024 | 11:21 AM
Rounders's Avatar
Rounders
My mistake. So ya,not the battery.
Old Apr 8, 2024 | 01:22 PM
TriGeezer's Avatar
TriGeezer
Have the battery load tested.
Old Apr 8, 2024 | 01:23 PM
im's Avatar
im
Does this motorcycle have an alarm?
Does alarm have a siren?
It is a long shot but some vehicle alarms have a rechargeable back-up battery that can cause weird problems.
Old Apr 12, 2024 | 01:57 PM
willy dog's Avatar
willy dog
Thought i had it figured out i charged the battery with a real charger, then load tested it it reads bad. This battery was bought new at the end of last year, and went dead after four days. This year i charged the battery upluged the radio fuse and the batt did not go dead, but it was warm out temp dropped and battery wont hold a charge .Have a new battery coming tomorrow will start over tomorrow. something is draining it but i will start with a fresh battery and troubleshoot from there.
Old Apr 12, 2024 | 02:18 PM
t150vej's Avatar
t150vej
If this is a mail order battery, put your test meter on it straight away, before charging. If it reads 12.2, check the date tag. If it's over 6 months old, don't waste your time installing it.
If it's coming to a local store, take your meter and ask to check it before you pay for it. Same specs apply and if deficient, leave it on the counter.
The AGMs will not tolerate being below 12.4 for very long at all and though a new one will charge up and do well, they will not last nearly as long as they should. Of course a strong parasitic is rough of them too.
Old Apr 12, 2024 | 04:13 PM
willy dog's Avatar
willy dog
Ordered another tender, think i will just leave it on all the time, the biggest problem is i don't ride it enough,find myself riding the sportster more and more, need to take longer rides with the bagger.
Old Apr 20, 2024 | 07:11 AM
willy dog's Avatar
willy dog
Well i feel like starting over, it's cold and raining outside good time to work on the bike, but it's cold and crappy out. This is what i know so far. Battery is fully charged with my multimeter at 200 ml and radio fuse unplugged i have a draw of .107 that seems to much. if i plug the radio fuse back in meter goes off the scale.If i put my meter to 10amps with everything plugged in it spicks to .03 then goes to .01 If i unplug the battery fuse i have no draw on the battery, Getting ready to just leave it on a tender and give up.
Old Apr 21, 2024 | 11:40 AM
t150vej's Avatar
t150vej
I never trust any range lower than 10A for automotive stuff anymore...
The high draw (20 - 40mA) when first putting power to a radio with memory (they all do anymore) is normal and the 10 mA constant draw is normal.
Old Apr 21, 2024 | 11:55 AM
WP50's Avatar
WP50
Even if you don't have a top notch meter those readings with meter set to 10amps are plenty good in my books.
It would seem to me you had a bad battery problem all along sir.
WP
Old Apr 21, 2024 | 12:14 PM
Rounders's Avatar
Rounders
I lost track of all the battery threads.
If you leave off tender for a few days after being on tender or good ride, will it start?
If it does, then leave on tender, maybe you just ain't riding enough to charge.
Though a bike should go a week fine,my 2007 with radio, no fob will go weeks. My 2015 with fob goes couple weeks, though they say charge new bikes if not riding weekly.
My tractor has a draw. I just disconnect to lazy to find it. Plus I don't know tractors.
The danger is bad battery or charging system and you don't know about.
Carry a jump pack. Be careful where you go for awhile
