Stock Pushrods?
Old Jun 25, 2024 | 09:29 AM
Sethc1020's Avatar
Sethc1020
Default Stock Pushrods?
Hows it going guys, I bought a set of SE 204s from a member here that came with new lifters and rocker arms. Since I will have to open up the rocker boxes anyway is there any issue reusing the stock Pushrods? Its a 2012 RGU 103 TC with a little over 18k miles on it.
Old Jun 25, 2024 | 09:32 AM
scott_0's Avatar
scott_0
as long as the cam shares the same base circle as stock cams, won't be a problem at all, when I installed Andrews 57H cams in my 2016 SGS, I reused my stock push rods, some builders push one piece (non-adjustable) push rods.
Old Jun 25, 2024 | 09:48 AM
MRFREEZE57's Avatar
MRFREEZE57
Unless you for some reason have to replace the rocker arms you will save yourself a lot of work by going to adjustable push rods.
Old Jun 25, 2024 | 10:01 AM
Sethc1020's Avatar
Sethc1020
Cams came with a set of rocker lockers as well so I figured Id just do it all while Im at it.
Old Jun 25, 2024 | 09:00 PM
hattitude's Avatar
hattitude
I believe the SE204 cams have the same base circle as OEM cams. You could always measure them with a digital caliper and compare with the OEM cams.....
I run SE203 cams, with OEM, solid pushrods in my '03 Heritage. It's quieter than my '01 Springer w/ OEM cams & OEM pushrods...
I too would reuse the OEM pushrods... I always prefer solid pushrods to adjustable pushrods whenever possible.
I could give a couple practical reasons, but bottom line is I prefer solid to adjustable.
I don't see going through the top as a ton of extra work.. I've had the rockers off my 2003 Heritage at least 5x over the years for various reasons... just not that much work to me..
I even ordered a custom size set of Smith Brothers solid pushrods for one of my bikes. It had OEM base circle cams, but I ordered a custom size just to get a little more preload in the lifters... I measured twice, ordered once...
Mikey 1450
Oct 9, 2023 11:07 AM
Mototech
Engine Mechanical Topics
19
Nov 30, 2017 02:55 PM
jimmything
Mar 22, 2016 06:34 AM
ElectricHead
Mar 4, 2013 02:25 PM
Road King Kid
Exhaust System Topics
11
Jan 7, 2008 06:08 PM
