Air chuck
Old Aug 6, 2024 | 02:36 PM
Sparkules's Avatar
Sparkules
Originally Posted by TheMurf
Suggestion. When you install new tires, buy and install 90 degree valve stems from Kurvy Girl. That solutions any problems putting air in your tires. Money well spent.
Yes indeed! Did this with the new tires in May. So much easier. Got a multi fitting air chuck with gauge from Amazon however with the straight extension on it (works best with the angle valve stems) it only reads accurate on the stem, pull it away and the gauge reading drops in half.
Whatever stems Kurvy Girl sells are dandy, fit correctly and don’t interfere with the brake calipers.
Old Aug 6, 2024 | 04:28 PM
Cle_rider's Avatar
Cle_rider
For the wheels on my EG standard (valve stem in center, facing straight up) I use a Jaco inflator with a 90 degree clip on adapter.
I have that one. Best one I have ever used. Clips on securely and pops off with the release.
Old Aug 6, 2024 | 06:05 PM
barneyboy's Avatar
barneyboy
Jaco dual 360° chuck for the win. You won't find a chuck that offers the versatility of the this chuck. No need to fuss with screw on extinctions.
Old Aug 6, 2024 | 10:37 PM
UrbanRunner's Avatar
UrbanRunner
These are what I use:
Old Aug 6, 2024 | 11:30 PM
gt06's Avatar
gt06
Some great suggestions folks. Thanks so much. I was at the dealer today for something else so I ordered the HD valve stem extension while I was there. Of course they didn't have one in stock like most things these days. I went for plugs and wires a couple days ago and they had to order those as well. Seems like they have to order just about everything and have very little in stock.
Old Aug 7, 2024 | 08:51 AM
Rogue8Man's Avatar
Rogue8Man
Little pricey but makes it supper easy
Old Aug 7, 2024 | 09:00 AM
Magnut1's Avatar
Magnut1
I also use this. I know it is expensive so I bought it for my birthday! LOL
Old Aug 7, 2024 | 11:52 AM
Tom H's Avatar
Tom H
Go with the JACO 360 and be happy. I have one at home and one where I help put. Works great.
Amazon Amazon
Tom
Old Aug 8, 2024 | 03:08 PM
big cahuna's Avatar
big cahuna
For fathers day this year, my son got me a compact tire inflator with a flexible hose. It's about the side of a walkie talkie, and the end of the hose screws onto the tire valve. You set it to what ever pressure you want, and it does the rest. It's also rechargeable. Not the fastest inflater out there, but it's relatively small and you don't need to provide power to it to make it work. It was cheaper than just the hose valve and gauge setup from Harley. I think it was $77.,,
Old Aug 8, 2024 | 08:51 PM
skratch's Avatar
skratch
i had one of those. i found that once you set your tire pressure, it'll run until it hits a point (overheat maybe?) and then stop. i have to do it again, and it'll go a little further and then stop. rinse and repeat. last week i had to air up a rear tire from 14 lbs to 42 psi. never got there. got as high as 37 and then it just wouldn't run long enough to increase psi.
i had some chrome cash so i bought the hd portable air pump. lets hope it works better. threw the other in the trash. was kinda bummed about losing the external usb port though.
SC_Compact
Oct 24, 2013 04:14 PM
Skippy97
Sep 25, 2013 01:05 PM
obidio
May 28, 2013 06:33 PM
willryder
Jan 22, 2012 06:32 PM
Bulldawg
Jul 24, 2007 07:08 AM
