Stalling
Old Aug 9, 2024 | 05:15 PM
TriGeezer's Avatar
TriGeezer
Check all battery & electrical power connections
Check ignition leads to coil
Check ignition switch
Load test battery
Check voltage at battery during a fast idle….should be greater than 13,7
Old Aug 9, 2024 | 05:40 PM
Bott's Avatar
Bott
Carb - Na, because it happened before the tune.
Battery - Going to say no to that because he was trying to start it for 30 minutes worth and shows voltage on reserve. Or say he's running total loss and the battery comes back up to start it...Don't believe it, but as of now without the static volte number, not it.
Crank sensor - Common type is the thermodynamics of it heating up and 'lights out,' cools and lights backup.
My closes guess from info explaining 'lights out.'
Old Aug 10, 2024 | 02:10 PM
Mr. Mike's Avatar
Mr. Mike
Originally Posted by YZR
The same thing happened to me after replacing the battery, it turned out to be a bad battery. Got a new one and no problems since.
I’m no genius, but this this post by YZR is what just happened to be. And like the OP, I tried to understand under what conditions the failure occurred. By the time I could coast to the roadside, the bike would fire right back up without sounding sluggish. And indeed after setting myself on fire after the second carb removal and going through everything fuel delivery wise, I noticed the mfg date on my RatedX battery was ‘17. Crap…nearly 7 years on that battery. Anyway, point is, the stalling while running and starting ok etc fooled me. New battery and haven’t a hiccup in over 400 miles. Slowly regaining faith in the bike to not strand be.
un-caged
Jul 25, 2017 02:03 PM
DP883C
General Topics/Tech Tips
Jun 2, 2017 12:15 AM
Huskerdoo
Nov 29, 2016 03:05 PM
pleasants9
Jan 31, 2011 10:16 AM
Big Hog
Exhaust System Topics
27
Sep 2, 2010 06:47 AM
