Bottom out sometimes
Old Oct 3, 2024 | 09:30 PM
NorthWestern's Avatar
NorthWestern
@Dano1998 Come back and let us know what you decide to do. I never see the results from the threads that you start. Good luck with your decision!
Good shocks are worth the money.
Old Oct 4, 2024 | 02:25 AM
im's Avatar
im
What did you use to add air?
Reason: the volume of air is minimal.
Requires a special no loss pump.
Several makers.
If you use a regular bicycle pump or pressure gauge then volume will go down and so will pressure.
Hopefully you will return with a response.
Old Jan 15, 2025 | 08:16 PM
Dano1998's Avatar
Dano1998
Default Rear Shox
I will be replacing the rear shocks next month (February)along with replacing both the oil and tranny drain plugs to a self tapping piggy back drain plugs. It’s winter up here in Connecticut it February we start getting warm days that remind you to get going on bike maintenance. Progressive has $300 shocks that are decent but they have a $500 shock that’s much better. I have to pick up a front fork rebuild kit . I have to replace all of the brake pads . Remove and replace primary oil and adjust clutch. I couple of days work I have coming up along with my Bassboat …….. where will I find the time fellas ?
Old Jan 16, 2025 | 06:36 AM
eighteight's Avatar
eighteight
Originally Posted by Dano1998
I I have to pick up a front fork rebuild kit . ?
I suggest you make sure that the air fittings at the top of forks don`t leak first.
Old Jan 17, 2025 | 07:37 AM
SSG_B's Avatar
SSG_B
Subscribed.
My Cousin has a 07 StreetGlide with leaking air shocks. Thanks for the link on how to rebuild them.
AllOutGraphics
Apr 21, 2021 09:29 PM
1badfxstc
Air Suspensions
Feb 1, 2020 08:40 PM
Capt.K
Air Suspensions
Sep 11, 2019 09:25 PM
crzyone9584
Exhaust System Topics
Sep 12, 2011 06:09 AM
