Check engine light when full throttle
Old Oct 21, 2024 | 04:03 PM
Max Headflow's Avatar
Max Headflow
Oops, Should have read the whole thing..
Old Oct 21, 2024 | 04:05 PM
Ed Ramberger's Avatar
Ed Ramberger
No worries, was not sure where you were going with it.
Old Nov 22, 2024 | 02:33 PM
RB808's Avatar
RB808
Thanks. I will try running the bike without the power commander.
Regarding the check engine light, it comes on for 4 seconds when I turn the bike to ignition, and then it does not come on again until the bike exceeds 4,000 rpms.
Appreciate all the information.
Old Nov 22, 2024 | 05:28 PM
Dano523's Avatar
Dano523
Again, pull history code to see where is pointing you to begin with in regards to sensors. Could be anyone of them, or if nothing is showing up as history code, could be low oil pressure at higher rpms, that could be acutal low oil pressure problem, or oil pressure sensor going south that MM does note have a code to show for that problem.
Hell, if the engine is built, but crank not re balanced for different weight pistons, could be as simple as engine vibration bad enough to dance the mercy ball in the band angle sensor on the cam position sensor off the wires just long enough to cause problems (will be code 44 for bank angle sensor.)
So again, what history codes are showing to start with, before we go down the rabbit hole deeper, since although there is not a direct code for misfire in the MM, that problem will still show up as another sensor code isntead. As for no history code and getting error light, that one points to a low oil pressure reading at the oil pressure sensor isntead.
As for codes that you don't want to see, 52 through 55, since all point to a cooked ecm that needs to be replaced instead.
Old Nov 22, 2024 | 06:15 PM
MCRD'71's Avatar
MCRD'71
Oil level?
Old Nov 24, 2024 | 11:56 AM
danaezabail's Avatar
danaezabail
The speedo won't have any codes for the ECM.. IIRC you need to short to pins on the diag connector and count the flashes on the motor light.. I'm no expert on Magneti Marelli tho..
__________________
LaughingJeager
General Topics/Tech Tips
Mar 3, 2020 05:10 PM
chief140sm
Jun 9, 2014 09:18 AM
wingshootin1275
Nov 24, 2013 08:53 AM
kevdog
Apr 8, 2008 06:29 PM
06bob
Jun 9, 2007 10:16 PM
