Slow start
Old Dec 1, 2024 | 10:00 AM
Maurice1's Avatar
Maurice1
Default Slow start
It's not the battery like I initially thought. Have a new yuasa 500cca and tests good. Ignition on shows slightly over 12v. Yesterday about 50-55 degrees and it barely started on the first try.
2021 roadglide limited with 22k miles. Does this sound like the starter to you guys? About to let dealer check it.
Old Dec 1, 2024 | 10:03 AM
702's Avatar
702
Did you fully charge the battery before you installed it?
Old Dec 1, 2024 | 10:10 AM
Maurice1's Avatar
Maurice1
yes sir.
Old Dec 1, 2024 | 10:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How did you test the battery?
Are you reading voltage with a voltmeter, or are you reading the gauge on the bike?
Do not buy a starter...
Old Dec 1, 2024 | 10:14 AM
memphisharley's Avatar
memphisharley
Originally Posted by Maurice1
yes sir.
with a charger or maintainer. low 12s sound low for a new fully charged battery. put a meter on it while cranking and see what the voltage is.
Old Dec 1, 2024 | 11:10 AM
Maurice1's Avatar
Maurice1
when I got the battery I checked with digital voltmeter, showed 12.5. Shop that installed it with new tires put on charger to top it off. Thus was a month ago.
Last battery was the same brand and CCA and I changed after 1 year because of same symptoms in 50 degree weather. Obviously it was not the battery.
Pretty damn sure it's not the battery again.
im retired and treated myself to this bike and servuce contract so i dont have to do anything on it myself. Time to be lazy.
couldn't it be the contacts to starter, or starter itself?
Is it a big deal to have that checked with a horrible cost?
Old Dec 1, 2024 | 11:13 AM
CoolBreeze3646's Avatar
CoolBreeze3646
May want to check your compression releases to ensure they are functioning.
Old Dec 1, 2024 | 11:21 AM
702's Avatar
702
Just because it read 12.5 volts doesn't mean it had a good charge. A battery can have a dead cell and still read 12.5 volts. If you trust that your shop did in fact fully charge it, great. I wouldn't. A brand new, fully charged battery, at rest, should be at nearly 13 volts. Good luck.
Old Dec 1, 2024 | 11:22 AM
ewhitefo's Avatar
ewhitefo
Try putting it on a trickle charge when not riding, see if it cranks normal. Maybe that will help to start isolating stuff that way maybe.
Old Dec 1, 2024 | 11:24 AM
Maurice1's Avatar
Maurice1
cannot put charger on it as no outlet in carport. Thanks though.
