For JMJOHN
when you use the standard J&M AeroMike III on the Harley system ,,, you would run the vox sensitivity about two blocks of adjustment back from being locked on to the right (2006-2008 system) or vox position 12 for the 1998-2005 systems,,,,,, and it works very, very well in that position ,,,,,,, we have used them on the Harley systems for years ,,,,
the problem is, is when you try and mix one Harley brand headset and one J&M brand headset on the same bike at the same time ,,,, then the vox settings for the two willl be incompatible ,,,,,,
now don't laugh ,, but there are alot of Harley riders who do NOT know how to adjust the intercom vox sensitivity settings on their system ,,, and those are the ones who really have problems ,,,,,,
the new -HO AeroMike III from J&M has a higher-output AeroMike that more closely matches the signal output from the Harley brand mike so that you can mix and match them on the same bike without problems ,,,,,,,
JMJOHN ,.,, john@jmcorp.com ,,,,,,
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
to really see the difference ,,,, I have pasted two of the headsets below from our website at www.jmcorp.com ,,,,,, one standard and one high-output model ,,,,,
Forum Members ,,,,,
I am using two sets of J&M headsets and still have to speak much loader than I did when I was using the stock headsets and have the VOX adjusted as you state. This is not a VOX setting or an issue with mixed brands of headsets. Mine are both as shown in the bottom picture. It is simply to much of a strain on your voice to want to use the intercom with this headset as it. Again, this not a VOX adjustment or using two different brands or even models of headsets. The particular headsets I have simply do not work well on my bike.
one of the advantages of the J&M mike over the Harley mike ((std or -HO model)) is that once you get the vox sensitivity adjustment correct for the headsets that you are using ,,,, the wind or ambient noise from the motorcycle will not false trigger the intercom like the Harley brand mikes do ,,,,,,
understand that I have had a new Ultra every year since 1989 and I ride often testing J&M headsets on the system to make sure we offer the best product available ,,,,,
I splice the J&M speakers to the Harley microphone so that I can hear exactly the differences between the Harley mikes and the J&M mikes ,,, so I know exactly how they respond to the vox circuits and what the ambient and wind noise comparisions are ,,, even with louder or modified exhaust ,,,,
and there is NO comparision between the J&M headsets and the Harley brand headsets ,,, the J&M's are a very significant improvement on the system and this is not a bashing of the Harley brand headset, only a summary of the major differences and benefits of the J&M brand headsets ,,,,,
JMJOHN ,,, john@jmcorp.com ,,,,,,
