Fall away test
Old Dec 7, 2024 | 08:14 PM
Whiskyjock's Avatar
Whiskyjock
Default Fall away test
I've got my 2013 Glide in my shop for its winter facelift and I'm going to do the fall away test on the front end. It's feeling a bit stiff. I'll disconnect the clutch cable. Is there a need to take the brake callipers off as well? Or anything else?
Old Dec 7, 2024 | 09:12 PM
Uncle Larry's Avatar
Uncle Larry
https://www.youtube.com/watch?v=uJzQPsE4AoE
https://www.youtube.com/watch?v=Oa6pvoa5KgY
Old Dec 7, 2024 | 10:40 PM
MRFREEZE57's Avatar
MRFREEZE57
I recently lubed my steering head bearings and just torqued the steering head nut to the specs, checked that was not too loose or tight but did not do the fall away check and it handles the same as before.
Old Dec 12, 2024 | 10:23 AM
skratch's Avatar
skratch
on your 2013, you do not do a fallaway test. you do a swing test. turn your handlebars all the way to one side and see how many swings it takes to get back to the center. and you said 'glide', if you are meaning roadglide, then you'll want the settings on the tighter side. there is a different spec for the batwing vs. sharknose fairing.
and be aware. that star nut on the stem takes very little movement to make a big change.
Old Dec 12, 2024 | 10:34 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Pull the steering stem off and clean and inspect the steering head bearings first.
Bearings may be ok, but you will probably find the grease has dried up.
In years past these bearings would go forever without service, but now the bikes have become super heavy.
On these heavy machines it is best to clean and inspect these bearings every 25k.
Old Jan 1, 2025 | 04:36 AM
N1265's Avatar
N1265
On my 2011 FLHTK I never did anything with the brakes on the swing test, just the clutch cable. SKRATCH is correct when he says that nut is touchy, I had to do mine multiple times until I got it right.
Old Jan 1, 2025 | 05:26 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I suspect the rollers are generally okay but the races get dented.
Old Jan 1, 2025 | 09:15 AM
Pix's Avatar
Pix
Got 96k on my 14 UL, Winter teardown includes replacing steering head bearings and races.
Tim "the drifter"
Touring Parts
Mar 29, 2024 03:33 AM
champ198
Oct 12, 2010 01:06 AM
hd0wner
Mar 11, 2009 08:28 AM
dbcoooper
Jun 18, 2008 09:37 PM
SPECIAL ED
Jun 27, 2007 01:23 AM
