Rear Tire removal
Old Sep 5, 2007 | 02:52 AM
reeac's Avatar
reeac
Default Rear Tire removal
I have an 07 Ultra and am thinking of putting the IDS on it. My question is it safe to use only the Sears yellow jack to change it or do I need a stand? I have never taken a rear wheel off before on a bike. Any advice on how to do it? I do have the mainteance manual.
Old Sep 5, 2007 | 03:50 AM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: Rear Tire removal
Used many bike lifts to pull the rear wheel... Just make sure your tie-downs are set right & TIGHT
Old Sep 5, 2007 | 05:40 AM
jbhawley's Avatar
jbhawley
the sears jack works great...just make sure you have the tie-down straps tights as mentioned above.
Old Sep 5, 2007 | 06:31 AM
dog155's Avatar
dog155
I drilled and taped four holes in the outside corners of my jack to clamp the frame to the jack.Like the boys mentioned above.Take the weight of either wheel off, and the bike will fall off the jack.
barkster99's Avatar
barkster99
Great question. I have the Sears red and wondering the same thing. IDS should be here today.
Old Sep 5, 2007 | 10:10 AM
cwilks's Avatar
cwilks
ORIGINAL: dog155
Not if its set correctly
Old Sep 5, 2007 | 10:14 AM
iclick's Avatar
iclick
ORIGINAL: cwilks
ORIGINAL: dog155
I have a lift I've had for 10 years, not a Sears, and I've never had a problem removing either wheel without support on the other end. In fact, this lift has no tie-down straps at all. I do use a hydraulic car jack under the wheel I'm removing, which is handy to lower the wheel in a controlled manner when the axle is removed, but balance with either or both wheels removed is never a problem.
Old Sep 5, 2007 | 10:32 AM
04RoadKing's Avatar
04RoadKing
I have the Red Sears Jack and it works great.
I have never used the straps and have never had any problems with my Road King wanting to fall off. I Wouldn't want to move the jack around in the garage with the wheels off but it's pretty stable just sitting on the stand with out moving it around. My opinion straping the bike down just to change the tires is over kill. But hey it's your jack and your Motorcycle.
Old Sep 5, 2007 | 10:34 AM
huffhuff's Avatar
huffhuff
i usually put the bike on the front porch so i can hang the tire where it's high off the ground for clearance. i use a ratchet strap to lower and then later to raise the wheel for reinstallation.
nazareth27
Apr 15, 2021 09:19 PM
drspencer
Dec 26, 2011 04:59 PM
2black1s
Dec 5, 2011 10:16 PM
rickss69
Detailing
Jun 29, 2011 11:05 PM
LDrider
Apr 20, 2008 03:21 PM
