white wall cleaner
Old Sep 5, 2007 | 07:04 PM
jeffca's Avatar
jeffca
Default white wall cleaner
I used Westleys bleach white on my 07 ultra and got some overspray on rims that wont come off I think im sick....dose anyone have a clue what i could use to remove these spots without having to buy a new rim? Jeff
Old Sep 5, 2007 | 07:08 PM
Softy's Avatar
Softy
Default RE: white wall cleaner
Try some wenol,that should take it off. It can't be that bad. I use wesley's all the time.
DB10881's Avatar
DB10881
Thats odd, i use Westleys all the time on my '03 and have never had a problem.
Old Sep 5, 2007 | 07:23 PM
notlost_nc's Avatar
notlost_nc
I use an SOS pad. A whole box lasts me more than a year. They also work good for cleaning the silver motor on the Evo
Old Sep 5, 2007 | 07:24 PM
oldhippie's Avatar
oldhippie
BOMS AWAY. or, a little Mothers Aluminum polish on the aluminum finish at the wheels circumference.
http://bikecleaner.com/
This stuff is great. I used it the other day after I left the Westley's on a bit too long. Don't worry the wheel will clean up fine.
I've been using the H-D tire and wheel cleaner since then.
Old Sep 5, 2007 | 07:26 PM
maineultraclassic's Avatar
maineultraclassic
Try some Nevr-dull and then use some mag/aluminum polish afterwards.......keeps my rims looking like new.
I never had any problems with Bleach-white staining rims either...............I used to use it all the time to clean my whitewalls and wheels with no problems at all. You can't beat Bleach-white and a SOS pad for cleaning whitewalls............nothing works better.
Steve
Old Sep 5, 2007 | 07:31 PM
SteveO's Avatar
SteveO
It will ruin aluminum if you let set and dry. I always wet the tire and wheel, whitewalls come real clean, and no wheel damage if kept wet.
Had a friend destroy a set of BBS wheels. Sprayed on all four tires and let sit and dry on the wheels.
Old Sep 5, 2007 | 07:35 PM
jeffca's Avatar
jeffca
Old Hippie Thanks I just ordered some BOMBS AWAY. I made the mistake ofleaving westleys on without washing off my fault
Old Sep 5, 2007 | 08:04 PM
woodeyewetzel's Avatar
woodeyewetzel
Next time take a rug and spray it with Simple Green and rub it on the whitewalls. Instantly clean and white
Old Sep 5, 2007 | 11:37 PM
goodbirds's Avatar
goodbirds
Can't go wrong with SOS pads. And if you rub very lightly, it will clean polished surfaces nicely.
loco2wlr
Apr 8, 2011 11:35 PM
Rockyriver
Jun 15, 2010 04:06 PM
Willy G.
May 29, 2008 01:29 PM
btefft
Aug 14, 2007 05:50 PM
Roadie 49
Detailing
16
May 30, 2007 09:16 PM
