BCM Reset
Old May 8, 2025 | 02:56 PM
itsmf's Avatar
itsmf
Default BCM Reset
what"s the best way to reset the BCM?
Old May 8, 2025 | 04:05 PM
Keithhu's Avatar
Keithhu
Curious why you think a BCM would need to be reset?
Old May 8, 2025 | 07:16 PM
hattitude's Avatar
hattitude
Might want to check for codes before resetting the BCM...
To reset the BCM...
Disconnect battery cables (Negative first, then Positive) after making sure the security is disarmed.
I leave it disconnected about 20-30 min, then just before reconnecting, briefly touch the Pos & Neg battery cables together.
Reconnect the battery cables (Positive first, then Negative).
The BCM should be reset.
If it has changed due to the newer ECMs, I am unaware of the changes... Someone will surely correct me...
Old May 8, 2025 | 07:44 PM
Max Headflow's Avatar
Max Headflow
One of these works really well..
Amazon Amazon
Old May 8, 2025 | 07:50 PM
YZR's Avatar
YZR
Very helpful.
Old May 8, 2025 | 08:02 PM
Max Headflow
Originally Posted by YZR
Very helpful.
You're welcome..
It might be better to answer Keith.
You a software guy?
Old May 9, 2025 | 01:00 PM
itsmf's Avatar
itsmf
Bike would"nt start after washing, threw U1040 code. Bcm module was:nt communicating with abs module. Before I could reset anything,the bike started after 2 days of doing nothing!
Thanks for all the suggestions.
Old May 9, 2025 | 01:04 PM
HD_noobie's Avatar
HD_noobie
Might want to go thru your connectors with some dielectric grease, something got wet.
Old May 9, 2025 | 01:10 PM
hattitude's Avatar
hattitude
Probably got a connector wet between the BCM and ABS modules, that caused the temp comm failure until it dried up.....
A judicious use of water when washing goes a long way...
Some things to to try that would prevent this....
Anytime I undo a connector for checks, mods, or maintenance... I add dielectric grease to the sealing portions on the connector.
When washing a bike I always try not to introduce water directly at electrical connections.. Certainly not pressure washers.
I often "dry" my bikes with one of the blower/driers on the market... Luckily, I bought mine before they got very expensive. Some just use a leaf blower. I focus the drier on any electrical connections that got wet..
I've yet to have this issue on my bikes after washing...
Old May 10, 2025 | 02:23 PM
itsmf's Avatar
itsmf
I always did everything you just mentioned when wsahing,first time it has happened in 48 years of riding.
