Low Voltage
Old Jul 26, 2025 | 08:51 AM
bcool's Avatar
bcool
Originally Posted by Baird
check those voltages using a decent DMM right at the battery terminals. I only use the fairing mounted voltmeter as a rough guide. There are a few connections on the path to the meter that can skew the indication. I also believe you can calibrate it if way off.
Is it throwing low voltage codes?
Thanks for the reply, Baird. Yep, checked it with voltmeter at the battery. I also have a usb plug in that shows volts and it and my shop voltmeter show the same, but the factory volt gauge in the panel has always read 1.5 volts high, but I live knowing that.
Thanks again!
Old Jul 26, 2025 | 07:10 PM
hattitude's Avatar
hattitude
Originally Posted by bcool
Thanks for the reply, Max. I may have misinterpreted the information in the manual. It states. [THE RUBBER MOLDED VOLTAGE REGULATOR AND STATOR CONNECTORS ARE NOT SERVICEABLE. DAMAGE TO TERMINALS, MOLDING OR LOCKING LATCHES REQUIRES VOLTAGE REGULATOR AND OR STATOR REPLACEMENT]
So it means IF the terminals are damaged.
I am getting only 12 ish volts at the battery until it is revved to 3,500 rpm. Stator does not smell burnt. Battery is one month old, same issue with old battery, terminals are clean. Since I am confident that I can disconnect the stator connector from the regulator, I will check the AC voltage and reply.
Thanks again for your help.
OK, as Max says, that is different...
There is a big difference between;
"THE RUBBER MOLDED VOLTAGE REGULATOR AND STATOR CONNECTORS ARE NOT SERVICEABLE. DAMAGE TO TERMINALS, MOLDING OR LOCKING LATCHES REQUIRES VOLTAGE REGULATOR AND OR STATOR REPLACEMENT",
and,
"my Harley service manual states that the regulator connectors are one time use only and once disconnected the regulator must be replaced."
They are fairly solid and sturdy connectors. Just use caution, and don't force anything. Make sure you can see/understand how the locking latches on the regulator work, so you can disable them properly, and you should be fine...
Old Oct 19, 2025 | 10:52 AM
bcool's Avatar
bcool
Just an update on my original post. I installed a new regulator a few weeks ago and it charges as it should now.
Thanks to everyone for the help!
Old Oct 19, 2025 | 06:19 PM
HarvHD's Avatar
HarvHD
Glad you got it sorted, and thanks for telling us the solution.
wrenchman9
Sep 3, 2015 09:31 PM
c50plus
Nov 25, 2012 06:50 AM
trackadaptor
Oct 16, 2011 10:24 AM
phaugly
Jun 30, 2011 04:54 AM
hazmatcar
Aug 22, 2006 08:15 PM
