Oil light
Old Aug 7, 2025 | 06:20 PM
Toneloco's Avatar
Toneloco
Default Oil light
After the top end redone installed a andrews 23 now oil light comes on only when hot and at idle do oil pumps loose volume when motor gets hot
Old Aug 7, 2025 | 07:26 PM
djl's Avatar
djl
It would help to know model, model year and details of modifications; need more information.
Old Aug 7, 2025 | 08:12 PM
hattitude's Avatar
hattitude
OP, more info would certainly be helpful...
However, I don't believe the oil light measures oil pump volume. I believe it measures oil pump pressure. Pressure and volume are different measurements. The idiot lights tend to be more accurate than the HD OEM gauges. And an idiot light indicating zero oil pressure, may also be an indication of no oil flow.
The bearings in an HD motor need flow, not pressure. So in the past, a sporadic low pressure condition at idle was not always an alarming condition.
However, if you are losing all oil pressure at idle consistently, and it's a new condition, I would investigate.
On a fresh top end rebuild, with the idle pressure lower than before the rebuild, I'd be curious as to why...
I'd start by putting a good pressure gauge on the engine (not an OEM HD gauge) to see what the pressures actually are. If no oil pressure was consistently measured at idle, I would suspect I made a mistake during reassembly of the top end rebuild.
Old Aug 7, 2025 | 10:15 PM
internet troll's Avatar
internet troll
As oil heats up, it looses viscosity. Imagine maple syrup just out of the freezer versus a bottle thats been sitting on the counter all day. You aren't losing volume, you are losing pressure. (yeah yeah, I fully understand how the 10W30 etc labeling works) Id assume you need to run a thicker oil.
Try the simple shet first.
For a while I was into older cars, all the new oils seemed to loose pressure when they got hot, I just started running straight 30 (SAE30) and it alleviated the problem.
Old Aug 8, 2025 | 05:09 AM
jake24lt's Avatar
jake24lt
Well if the oil light wasn't coming on before you put the cam in it. I would revisit the work you did on the cam chest.
Old Aug 8, 2025 | 07:26 AM
memphisharley's Avatar
memphisharley
yep...specifically that oil pump oring install.
Robert Strohl
May 8, 2012 12:15 PM
HD2001SUPER_GLIDE
Oil Archive (no new posts)
Jul 19, 2010 08:58 PM
Spur56
Jul 1, 2010 12:57 PM
Smokedawg
Jul 17, 2008 08:46 PM
smathisen
Screamin Eagle CVO Models
Aug 17, 2007 02:27 PM
