Parent metal bearings.....
In typical Harley-Davidson fashion, it turns out that the '06 Dynas were the testbed for things to come. All of the '07 Twin Cams now have the same cam components that debuted on those Dynas. As of press time, H-D doesn't offer those '06/'07 parts to retrofit earlier Twinkies. We don't know if they will, but Andrews Products has designed cams and other integral parts to combine with factory H-D parts to convert any Twin Cam into '07 specs.
Not sure I like the idea of going without ball or roller bearings in the cam plate. To let the 'oil' be the only thing that keeps the metals from fusing seems to be a big risk.
2007 is the first year.
Reduce cost and complexity yes, but I'll take bearings any day and I don't buy the part of increased durability, no way. And it's not even a plain bearing as "glens" stated, it's just a machined part of the parent metal without even a plain bronze bearing inserted in it.
I don't know exactly how much cheaper it would be than to use a roller or ball bearing anyway. Roughly the same amount of machining will be required either way (plain/rolling) but with the plain bearing the machining on both affected surfaces would have to be of a higher order; I'm pretty sure. Maybe in the end it wound up (so far) to be more cost effective to do it this way but I'll put my money on noise level being at least partially a driving force. Note the inner bearings are rollers of some type and that they're buried deep inside the cases where their noise level will be less discernible.
Don't forget that the EPA noise pollution regs don't discriminate regarding the source of the noise, just that it can only be such a level. By making the outer camshaft bearing a plain design, whether it cost more or less, they probably saved a half-dB for the left muffler to use.
...I'll put my money on noise level being at least partially a driving force...
...Don't forget that the EPA noise pollution regs don't discriminate regarding the source of the noise, just that it can only be such a level...
In an issue of American Rider a few months back, they interviewed one of the big whigs at H-D (if anyone cares I can dig up the issue & get names) and he stated that HD doesn't have a problem meeting emissions regs, and that they will have a harder time meeting EPA noise regulations than they will emissions regulations in the future. Air-cooled engines, especially OHV engines, are not at all quiet when compared to a water-cooled engines as they don't have water jackets to insulate the noise.
So if indeed we see H20 Glides in the future, it's more likely they will come about courtesy of the EPA's noise restrictions rather than emissions restrictions.
Who'da thunk it...
On an off-topic note... [sm=rant.gif]
The EPA- Environmental Protection Agency. What a joke. They are hell & gone from their original reason for being- protecting the environment. If you ever read up on how they "oversee" corporations and big industry you'll see how, in typical bureaucratic fashion, they have FUBAR'd the entire system so bad it can never be made to function properly. The manufacturing industry is pumping all sorts of poisons into the environment and cranking out 8 mpg SUV's by the thousands, while the EPA is humping the motorcycle industry's collective leg about a half a dB of noise coming from an engine delivering 50-60+ mpg.
What a sad sad state of affairs...
(OK, I'm done...
)The Best of Harley-Davidson for Lifelong Riders
As wear occurs over the years within the bearing, this oil film thickness does not increase like you would find in worn roller bearings. The oil film thickness will always remain the same, the change will be the radial position of the shaft inside of the bearing (it is never on center but rather in direction of total load vectors). Also fluid-film bearings provide increased cooling abilities as the oil itself removes the heat generated within the bearing. Since the strength of thebearing material is not being used to support the loads, different bearing materials can be used that dissipate heat much faster such as chromium copper alloys. These are not "bronze bushings" as suggested but rather high-tech, highly efficient bearings used commonly in higher capacity engines and machinery. They are not even machined, but rather rolled from flat stock after the flash coating is done and designed to have what is called "crush" on them to establish the best vibration damping characteristics as well as to ensure a slightly elliptical close tolerance bore after installed for better oil flow and wedge configuration.
Outside the industrial machinery world little is known about fluid-film bearings, but they have been around for 50-60 years and are not something HD tho
Old style babbet bearings as used in autos are great as long as you keep heat down, oil clean and at the right pressure and most importantly volume.
Too much pressure will actually erode the babbeting off the base metal and heat breaks the oil down so you are no longer riding on the thin film of oil.
Newer oils withstsand the heat and break down better.
Allliquid cooled motors run slightly cooler at standstill or bumper to bumper traffic than our HD'S do. Thus the in head cam journals last longer.
But replace one that has failed. In many cases the bare head (no parts in it) is $400 plus dollars.
I imagine for the most part this new cam plate will hold up until the warranty runs out. Which is all the MOCO cares about.
They could care less how much it costs YOU to repair it afterwards.
Nope newer is not always better for the consumer.
Another reason for me to not upgrade.
