trans issue help needed
Old Aug 13, 2025 | 09:47 PM
rubberguy's Avatar
rubberguy
Question trans issue help needed
2007 FLHTCU 6 Speed. had to replace 3 - 4 gear shift fork and 3 - 4 pocketed dog slider. problem is according to manual the torque spec on the mainshaft and countershaft jam nuts on the trap door is 50 ft. lbs. But if i go over 30 ft lbs the trans locks up! what do i look for to remedy this. any and all help is appreciated. Thanks in advance. Bill
Old Aug 13, 2025 | 10:06 PM
ridingout's Avatar
ridingout
Are you sure it is supposed to be ft lbs and not inch lbs. ? I don't know just a suggestion
Old Aug 13, 2025 | 10:24 PM
rubberguy's Avatar
rubberguy
45-55 foot pounds. double checked manual but thanks
Old Aug 14, 2025 | 06:02 AM
Ultrascott's Avatar
Ultrascott
if it is locking up when tightening the nut then there is something assembled incorrectly. i would recheck orientation of everything and see what you can find
Old Aug 14, 2025 | 10:56 PM
rubberguy's Avatar
rubberguy
tore it apart again and greased up all the channels for the 6, each 1/2 circle clips. put it back together and all is good now. thanks all
Mark Ballantine
Aug 1, 2023 10:06 AM
lunar00
May 25, 2017 10:00 AM
AlanStansbery
EVO
17
Apr 17, 2016 11:53 AM
Rotti2
Oct 16, 2010 08:07 AM
lencap
Oct 8, 2007 10:33 AM
