Every ******** year with these batteries.
Hopefully someone can see something wrong.
The battery clips are the wrong color because I used tender clips - the colors will be backwards using them this way on the tender plug.
Edit to add - the battery cables, ground under the starter, main fuse contacts, even the starter itself have all been checked multiple times or replaced and are good. There is no parasitic draw beyond the bus draw which is under 40mA and would likely go down after some time. I have even pulled the main fuse overnight - no appreciable change to float voltage the next day.
The bike is stored in a climate controlled garage each night and there are no aftermarket heated or high draw accessories.
I see nothing bad, or alarming in that video.
The static charge is 12.7V which is a full charge. That's good.
The battery drops when started, but never goes below 10V. That's a poor man's load test. It shows that current battery is good.
The charge voltage never goes over 14V and is up over 13v. That's good.
By the way, that "Motocross Platinum Elite AGM, GYZ32HL" is a rebranded Yuasa Battery, GYZ series. It's the same battery (series & size) that I put in my baggers and have had great service from. I buy it with the Yuasa name, but use a GYZ32HL battery.
There is nothing in that video that shows me why you don't get better service from your batteries...
That suggests to me it's your storage habits, use habits, and/or environmental conditions that shorten your battery life
I re-read your first post, there is nothing unusual, except for the low temps you routinely run the bike in...
You ride in really cold weather, 35° and less. Do you use the proper weight oil for those conditions?
If all is well mechanically (starter, auto compression releases, etc), that is all I can think of....
According to Google AI temps should be higher for colder temps.
Sold by a lot of different manufacturers.
You can turn it on and off.
While I love the old school analog dials on my older Electra Glide, I can't tell tenths of a volt difference like this plugin.
Nice to plug/cover the connection if your batter tender connection cap is missing too.
I just leaveit on the bike.
I just leave it on the bike.
At least nothing like the newer bikes just sitting there.
They do sell them without the USBs.
https://a.co/d/0BsQ6Xo
In my job I drive all sorts of vehicles, vans, trucks, and forklifts. NEVER seen anything charge close to 15 volts. Maybe every situation I have been exposed to in the past several decades has been out of the norm, but I kinda doubt it. From what the OP is showing I don't think the problem is in the charging system unless it does go too high every now and then when he is out on the road. I wonder if it is possible that the battery box is somehow loose and shaking the battery more than normal?
Anyhow OP I wish you luck. Even on my bikes with heavily upgraded stereos in them I still get several years out of regular AGM batteries.
Like I said the HD systems seem to be geared towards putting out 14.4 volts. I've seen higher but usually after some idiot adjusted the regulator on a 65 pan or 78 honda 750. I had a regulator fail on one bike and cook a LI battery. I've been working MCs since the 60s. The old analog voltmeters, like a Simpson 260, weren't that accurate.
One suggestion I'd make to the OP is to find a battery charger / maintainer that does temp compensate if the bike is stored below 60F.
