Stripped threads on outer primary.
How can I fix this? Considering how the primary works and since the fluid stays low to lube the chain, I don't really think I'm in danger of it leaking, especially with the surrounding bolts tightened to spec. That said, I still want to fix it. Believe it or not, this is the first stripped bolt hole I've had to deal with. Advice is appreciated.
Many times the factory will thread holes deeper than bolt.
For example if hole continues for 0.5 inches more then just find or cut a bolt to just 1/4 inch longer than current bolt.
Didn't work on an intake manifold on another tread recently.
Try running in a bottom tap to clear thread and get it threaded to bottom of hole. Be gentle.
Then run a long threaded bolt in it to the bottom. Mark the length so a cap nut will tighten but not bottom .
Screw it out and use a hacksaw to make your all thread stud. I also saw a screw driver slot in it. Snug it in.
Now try it with the cap nut.
I personally don't use a torque wrench on small fastners in aluminum. When there wet with oil, spec is way too much.
I put a thin film of black RTV on gasket. Snung them all in. Then in proper order, snug them lightly with T handle socket between my fingers.
I let RTV that's about size of a small rubber band dry and it will just sheer off when you push it back toward engine.
First heat cycle, I recheck.
Worth a try.
PS.. Permatex Ultra Black RTV. Just a film put down on gasket on piece of clean cardboard. Not a layer. And use Harley's V shaped gasket. And let it dry before removing that band, that maybe comes out, or you will make a mess.
That little RTV fills any little scratches in cover and provides a long time no leak job. The 04 I gave to my son is still dry and been years since it was apart.
When everything is hot, there a lot of movement in those long aluminum parts.
The tap is called a nut tap. You're probably not going to find that cheap. I see one for $15 but most are $70 ...
Just put a notch in a good bolt and clean thread.
I have a few fine thread nut taps.. One is 5.5 long but it's 5/16 -24 Fine thread.,
The 1/4-20 I have is 5". But it has a lot of chamfer designed to make long stand off nuts on a turret lathe and not break. Didn't work. One of the first jobs I worked with engineering to change a DWG. I ask why we couldn't just tap each end. They said sure..
Some of my tools go back 50+ years in my career.
