deka ETX30LA AGM battery life expentency
Old Mar 17, 2026 | 07:50 PM
Streetrunner's Avatar
Streetrunner
Default deka ETX30LA AGM battery life expentency
I have a Deka EXT30LA AGM battery in my 2010 FLHTC. Its 5 1/2 years old, still starts strong. I keep it on a tender. I have heard the AGM batteries can last about 9 yrs but don’t know if thats true. If its not true I realize I should replace the battery. Any insight on my question? Also would the Big Crank ETX30LA be a better choice than the Deka? They both have the same specs.
Old Mar 17, 2026 | 09:12 PM
GalvTexGuy's Avatar
GalvTexGuy
I believe they’re both made by East Penn Manufacturing.
Old Mar 18, 2026 | 12:05 AM
Streetrunner
bottom line, is it time for a new battery or should I roll the dice?
Old Mar 18, 2026 | 01:50 AM
Keithhu's Avatar
Keithhu
Replace it, they're cheap. At this point what's the payoff from "rolling the dice"? SMH
Old Mar 18, 2026 | 05:35 AM
danny54's Avatar
danny54
Here in florida i usually get two to three years max
Old Mar 18, 2026 | 05:58 AM
MURPHCC1's Avatar
MURPHCC1
You got your moneys worth at 5 1/2 years, dont roll the dice on this one.
Old Mar 18, 2026 | 06:12 AM
Jackie Paper's Avatar
Jackie Paper
I would get a new battery. Batteries do last longer in cooler climates.
One thing about keeping it on a maintenance charger. Iit doesn't hurt the battery but I guarantee the last start you may get is when you leave home.
That actually may be more then one thing. Anyway, my advice is always free.
Get you something similar to this. Battery purchased 2017 that's in my bike. Bikes been setting since 2023 or so but has been maintained ever 6 months. Battery came off maintenance charger. What one quick start did to it. It's actually not in great condition.
Can you see why?
Old Mar 18, 2026 | 06:40 AM
eighteight's Avatar
eighteight
Run it till it fails
That always happens in your driveway....
Old Mar 18, 2026 | 06:56 AM
2goldens's Avatar
2goldens
For me, when a battery gets questionable I remove it from the vehicle, give a full charge and then load test it. I also have a cheapo Harbor Freight tester that has you input the CCA and then it tests it and gives you a percentage of the capacity that the battery is good for and the resistance. Similar (but probably not as good quality) as the one Jackie posted earlier.
Old Mar 18, 2026 | 07:06 AM
hardheaded's Avatar
hardheaded
I have one that is pushing 4 years old and am going to replace very some. Gotta get some heart work done next week and going to wait to see how long before i can ride again before springing for a new one.
