switch housing
Old Apr 12, 2026 | 02:14 PM
willybsure's Avatar
willybsure
5th Gear
Default switch housing
2013 road glide costume no top screw on switch housing .. how do I remove
Old Apr 13, 2026 | 06:21 AM
strokelessone's Avatar
strokelessone
If there aren't any visible screws, look for indentations that you can insert a small flat screwdriver blade into.
Old Apr 13, 2026 | 06:51 AM
Rounders's Avatar
Rounders
If you pull the lever off does it reveal a screw? I would not start prying.
If factory look at parts diagram.
Old Apr 13, 2026 | 07:00 AM
eighteight's Avatar
eighteight
Stock has 2 screws from the BOTTOM
Old Apr 13, 2026 | 07:14 AM
touchdown's Avatar
touchdown
Bottom up
Old Apr 13, 2026 | 09:08 AM
hattitude's Avatar
hattitude
Old Apr 13, 2026 | 09:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Not on any motorcycle.
@willybsure
Why are you removing the switch cover, and what side?
Maybe you should ask some more questions before you pull the switch apart, since it is obvious you have never done this before...
Old Apr 13, 2026 | 10:57 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Get you a genuine Harley Davidson Service Manual for your bike and all mysteries will be revealed
Old Apr 13, 2026 | 01:20 PM
Architect's Avatar
Architect
If you can't find two screws, maybe you should bring that bike to someone before you make it worse. Good luck.
Old Apr 13, 2026 | 04:03 PM
CoolBreeze3646
Next up:
My turn signals don't work.
The bike won't start.
Or
My throttle does not work correctly and I have a high idle................
Tattoo 72
Blowers/Turbos/Nitrous Oxide
Dec 6, 2022 11:00 AM
soulpatch
May 27, 2019 01:14 AM
Drtumolo
Audio Systems
11
Jun 26, 2017 05:24 PM
LKHA
2014-2024 Touring Models
Dec 29, 2014 09:25 PM
quickster47
Sep 10, 2012 11:37 AM
