Metallic rattle under hard acceleration
Old May 27, 2026 | 07:23 PM
Mr. Mike's Avatar
Mr. Mike
Take a look at your plugs as they can tell a story.
Pre detonation, lugging, different tune etc. I dunno, but I brought my carbureted FLHT from CA to Utah four years ago and never had an ignition related problem. Not sayin’ this is or isn’t your issue, but you can check it out in 30 minutes in your own garage. I Did run premium fuel and plugs always looked light tan. We’re at 5,354 elev. and the interstate is 80mph down here and it’s always a kick to jump on it when you’ve got the acceleration lane all to yourself.
Old May 27, 2026 | 09:59 PM
02fx's Avatar
02fx
Detonation (pinging)=hole in piston=big bucks. Have a mechanic take it for a ride he will tell you in a minute if it's detonating. Common causes are lean, high compression, low octane gas , improperly timed ignition.
Old May 28, 2026 | 11:05 AM
TheMurf's Avatar
TheMurf
Default Rattle
Check the timing, run high.octain gas and downshift if it starts to ping .
Old May 28, 2026 | 12:41 PM
hardheaded's Avatar
hardheaded
Carbon on top of the pistons are a big cause also. Sucking hot ,oily air from the breathers back into the engine will cause it too.
You could try spraying water into the intake while keeping the rpm's up to clean the engine up. WARNING go slowly with this. Put some RedLine fuel treatment in it too.
Look at the plugs, they will give you a clue what is happening. While the plugs are out get a camera and take a look at the top of the pistons to see how much carbon is on top of them. Good Luck !
Old May 28, 2026 | 08:23 PM
1973Plymouth's Avatar
1973Plymouth
6th Gear
I had the same thing a couple weeks ago, loose bolt on the air cleaner cover.
Old May 29, 2026 | 08:44 AM
Bullwinkle58's Avatar
Bullwinkle58
Does it rattle in neutral at that rpm? I would check the exhaust heat shields first.
Your bike 100% needs a tune regardless.
I ran with that setup (air cleaner & slip-on's) and a stock tune for quite a while. Too long, honestly. In the summer I was getting detonation on long uphill highway sections when it was hot, and the rear cylinder would shut down in city traffic all the time. It had decel pop like crazy. I don't have plans to upgrade the motor beyond OEM, so I found a deal on a Vance & Hines FP4 and it worked fine. The app & bluetooth connection is terrible, but the tune is installed and it runs great.
Old May 29, 2026 | 09:01 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by sdreeves
Or is it normal for the engine to be a bit noisy under hard acceleration? Thank you
If you lug the engine...
Old May 29, 2026 | 10:07 AM
jake24lt's Avatar
jake24lt
Are you running OEM spark plugs
Old May 29, 2026 | 12:49 PM
sdreeves's Avatar
sdreeves
I'm gonna get the tune but do I need to get a power vision or would the dealers screaming eagle tune suffice? I've heard since it's epa compliant it's still on the lean side. I'm fine with the way it runs now I just don't want to hurt the engine if it's pinging.
Old May 29, 2026 | 12:53 PM
sdreeves's Avatar
sdreeves
I actually don't know. I haven't even looked at them since I got the bike last year. I misplaced a lot of my tools in the move and I'm not sure if I even have a spark plug socket anymore so I'll have to get a new one. They're probably old as hell though so I should just get new ones. If I take it to the dealer for a screaming eagle tune I can have them throw on stock plugs. Or should I be getting a different brand?
