Any problems withusing a 5X10 utility trailer
Old Sep 19, 2007 | 10:08 AM
Chief X's Avatar
Chief X
Former Sponsor
Default RE: Any problems withusing a 5X10 utility trailer
We have a 5x10 utility trailer that we use along with our large enclosed trailer. I have taken the 5x10 from NY to Deals Gap 2 times, to Sturgis and back and several shorter trips. I haul sport bikes and my Streetglide. Your trailer and truck should do fine for that distance. As far as negative comments about trailering - we have no choice because we carry goods for shows. Some people have tunnel vision. Don't let them bother you.
Chief
Old Sep 19, 2007 | 10:13 AM
huffhuff's Avatar
huffhuff
take the windshield off if you can to lower profile.
Old Sep 19, 2007 | 11:06 AM
harley0711's Avatar
harley0711
My wife has a 96 Avalon and we have pulled a Kendon with our EG on it from Northern Ca to Vegas, Or and WA several times... I have now sold that and just ordered a Wells Cargo - Road force - I plan to retire this year and we have plans to drive to several spots around the US and then ride - back in the trailer and find another spot... I also plan to us this device http://www.bikersgostrapless.com/ I have seen this and also talked to a custome bike builder in Fresno CA (Thunderstrike Motorcycles 14634 Highway 41, Madera, CA (559) 822-4220) who has used these for over a year - at first he would use a saftey strap but now - just the device... It makes loading a bike super easy...
Old Sep 19, 2007 | 09:21 PM
LeadDoggy's Avatar
LeadDoggy
Harbor freight fold-up, 12" tires and LeadDoggy's fabrications
Old Sep 20, 2007 | 09:28 AM
huskers11's Avatar
huskers11
Sounds like you should be fine. If you do have problems, that why you have insurance.
Old Oct 19, 2007 | 02:21 PM
phatmitzu's Avatar
phatmitzu
4x6 foldable trailer with 20" tires.
You should be fine with 5x10. Just check your wheel bearings from time to time.
Old Oct 19, 2007 | 08:06 PM
jeepster09's Avatar
jeepster09
ORIGINAL: xxxflhrci
ORIGINAL: TexasRedneck
My only concern would be the size of the tires on the trailer.
Why for such a light load?
12 inchers are usually rated at 1100lbs each. I have a '76 trailer with 12 inchers that has seen tens of thousands of interstate miles and never had a problem
The fat 10 inchers come rated up thru E. You can put a big load on them. I have a 1800lb Apache camper that has been all over the country riding on 10" C rated tires.
The main thing with smaller diameter tires is to keep them aired up correctly. Regardless of what size you have, be sure to have a good spare.
Ever notice that the small tired ones are usually the ones sitting on the side of the road? The small tires make the wheel bearings go about a "million miles an hour" and smokes the bearings.[]
Go with a larger size wheel and slow down the bearings and make sure they have been re-packed somewhat recently.You will be much happier.
Old Oct 19, 2007 | 08:12 PM
1flhtk4me's Avatar
1flhtk4me
Make sure the tires are in good shape.No cracks in sidewalls and check the valve stems for cracks also.Carry a spare.
Old Oct 19, 2007 | 08:38 PM
NSBRK's Avatar
NSBRK
Invest in a 2ton floor jack and a quality lug wrench for the trip.
Old Oct 19, 2007 | 08:52 PM
Mountainkowboy's Avatar
Mountainkowboy
We pull the RK all the time on a Harbor Freight 5x8 with 12" wheels all the time behind the RV when the wife wants a break from driving. I check the bearings regularly and make sure they are greased and that the tire preasure is good. I wouldnt hesitate.
