adjustable backrest
Old Sep 24, 2007 | 12:28 AM
jahays32's Avatar
jahays32
Default adjustable backrest
I will be installing the back rest and in MOM it say's to remove the seat strap, ok so here is my question. Do I remove the seat strap little screw or do I remove the seat strap bolt that also has the quick disconnect bracket on it for the hard bag? If it is the latter can you get the quick disconnect bracket off when going back or does it only go on in one position?
Old Sep 24, 2007 | 12:41 AM
dawg's Avatar
dawg
Default RE: adjustable backrest
The seat strap can be removed by unscrewing the screw on the left side of the scoot and you can leave it attached on the right and put it all back together if you want when you are done. Or you can remove it permanently by taking out the brackets. You will have to put the saddlebag bracket back on but if you have a little bit of dust on your frame like I did, you should see right where it goes If not, just mark the top edge prior to taking it off.
Old Sep 24, 2007 | 02:00 AM
PapaTravis's Avatar
PapaTravis
Hey dawg. I am going to remove the strap, should I put some spacers in place of the strap buckle?
Old Sep 24, 2007 | 03:07 AM
dawg's Avatar
dawg
ORIGINAL: PapaTravis
My strap buckle was on the outside of the saddlebag clip connectors. Are yours underneath the clips?
Old Sep 24, 2007 | 08:13 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Leave the strap off IMO
Old Sep 24, 2007 | 09:47 AM
stillwater's Avatar
stillwater
When I put on my solo, I remove the strap and put in nylon washers to prevent scratching. I think most States and Provinceslegally require a strap for the passenger if you have aseat for 'em.
Old Sep 24, 2007 | 01:48 PM
dstockton's Avatar
dstockton
I left my strap on so that it covers the gap in the seat when I don't have the backrest installed. I only use the backrest on trips.
Old Sep 24, 2007 | 02:07 PM
Scootr's Avatar
Scootr
I left the strap off also. Makes it much easier to remove / swap seats and looks cleaner imo.
Old Sep 24, 2007 | 02:29 PM
dgriffith's Avatar
dgriffith
I took the strap off when I installed the pass. grab handles and accessory covers Only now my rug falls off on hot weather.. Don`t laugh. A $ .97 entry door tied yarn mat does wonders in hot weather. Multi colored or solid at Wall-Mart
Old Sep 24, 2007 | 02:53 PM
Shmeck's Avatar
Shmeck
I like the strap off too IMO
