rattle on deceleration
Old Oct 3, 2007 | 04:28 PM
RK Rider's Avatar
RK Rider
2nd Gear
Default rattle on deceleration
I have an 05 Road King Classic. I get a tinny rattle or vibration when I decelerate and it seems to be coming from the front forks-but I am not sure. Three people have tried to pinpoint the source and so far, no luck. The noice doesn't change when I take off the windscreen. The pipes seem to be attached solidly to the bike, so I don't think they are rattling. Has anyone else run into this problem? Any ideas?
Old Oct 3, 2007 | 04:46 PM
gunrunner's Avatar
gunrunner
Default RE: rattle on deceleration
Heat shields will do it .
Old Oct 3, 2007 | 05:07 PM
RK Rider's Avatar
RK Rider
2nd Gear
Thanks for the reply. I checked the heat shields around the pipes and they seem solid. It sounds like a spring rattling inside the fork?
Old Oct 3, 2007 | 05:28 PM
Retired_Ted's Avatar
Retired_Ted
Probably part of the headlamp nacelle - that little trim piece that runs along the center of the headlamp housing can vibrate at the back. Try to wiggle it - if it moves, you need to snug a piece of foam or something under it to dampen the vibration. I had the same problem, btw, with my RK.
Old Oct 4, 2007 | 01:15 PM
RK Rider's Avatar
RK Rider
2nd Gear
Thanks, I try it.
Old Oct 5, 2007 | 08:08 AM
NCCopBikeRider's Avatar
NCCopBikeRider
Are you using the detachable tour pack/sissy bar hardware?
It will rattle after a few miles
Old Oct 5, 2007 | 09:33 AM
RK Rider's Avatar
RK Rider
2nd Gear
Thanks for the tip. I have the detachable windscreen but the rattle happens whether I have the windscreenon or off.
Old Oct 5, 2007 | 10:20 AM
Silverearl's Avatar
Silverearl
Okay here is one for you to try. Check the timing cover. I had a rattle at 2k and no one could find it then I had it at the Dealer and a tech looked at it for a minute and touched the cover and Bammm It was not doing it anymore.. Go figure I out up with it for a good 3-4 months and could not finf it..
Old Oct 5, 2007 | 11:43 AM
RK Rider's Avatar
RK Rider
2nd Gear
Thanks, I'll have to get out my manual and figure out what the timing cover looks like.
swampfox_csa
Jul 10, 2012 01:28 PM
smtrickett
May 26, 2011 11:48 AM
redclassic
Apr 12, 2008 05:08 PM
NikoNY
Jul 8, 2006 12:20 PM
lbnich
May 22, 2006 03:38 PM
