sppedo problem
Old Oct 7, 2007 | 02:00 PM
MR. SCOOTINN's Avatar
MR. SCOOTINN
Default sppedo problem
ok here it is...i was on the bike today about 60 miles from home,,,speedo started bouncing & then went totally to zeroo,,,,miles were not changing either on digital part of the speedo....the the bike started to die when ever i let of the throttle totally... restarted it ..black smoke from tail pipe...made it home down shiffting at lights to restart bike ...but have to figure out what is going on,,,any help would be great...thanks..
Old Oct 7, 2007 | 02:36 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: sppedo problem
Ah have a feelin' yer havin' a battery/stator issue - sounds like low voltage ta me.
Old Oct 7, 2007 | 02:40 PM
GrayRider's Avatar
GrayRider
Speed sensor..common problem.
Old Oct 7, 2007 | 02:48 PM
TexasRedneck
If he wasn't havin' the other issues w/the bike runnin' properly, ah'd agree on the speedo sensor - or are they interfaced somehow?
Old Oct 7, 2007 | 02:49 PM
Timex's Avatar
Timex
Same thought here. Although it could be a charging, low voltage issue as well. Check the charging output.
ORIGINAL: GrayRider
Old Oct 7, 2007 | 03:32 PM
Retired_Ted's Avatar
Retired_Ted
Check your battery cables - oxidized or loose ??
Old Oct 7, 2007 | 04:06 PM
daconiam's Avatar
daconiam
Voltage regulator prob....
Old Oct 7, 2007 | 04:11 PM
GrayRider's Avatar
GrayRider
ORIGINAL: TexasRedneck
The speed sensor sends info to the ignition, EFI and speedometer. They get dirty and can sometimes be taken out and cleaned. If not, they have to be replaced. Easy thing to check, easy fix. Common problem.
Old Oct 7, 2007 | 04:32 PM
MR. SCOOTINN
apprecitae the info...just to let everyone know...it has a baker 6 speed trans...& according to gagues volts were good...thanks..
Old Oct 7, 2007 | 06:53 PM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
According to your gauge .. the voltage to your gauge was good.
