Primary Change
Old Oct 8, 2007 | 06:04 PM
cowboyglide's Avatar
cowboyglide
Default RE: Primary Change
ORIGINAL: brinks13081
Ok, so if I just drained it, then 38oz is enough?
Yes.
Old Oct 8, 2007 | 08:39 PM
Mr.Dull's Avatar
Mr.Dull
BUT someone has posted in the oil section that he has added sixty Oz. to his primary!!!!!!!! Come on, get real here!
EZ
Hi, that someone was me. Yes thats correct just under 2 quarts to reach the bottom of the clutch basket and no I wasn't changing it out in my yard. On the lift on a concrete garage floor. Hey I been wrenching since my old Bennelli in the late 60's and I have a lot of respect for any engineer & what the manual says but I only tell you what I experienced. 32 oz bottle (1 quart) could not even see the level. Just under 2 quarts came up to the clutch basket on my 06 Elect. So far the clutch works fine.
Old Oct 8, 2007 | 09:16 PM
jammerx's Avatar
jammerx
I cant speak for the 08's (what does your owners manual say) but I will impart this on ya,if you dont overfill it or underfill it a bit it won't leak. That oil is being literally flung all around keeping the chain and the basket in a oil bath. so an oz here or there shouldnt matter really. Now alotta ozs and your gonna have some issues...
Old Oct 8, 2007 | 09:32 PM
brinks13081's Avatar
brinks13081
We'll I added 38oz, and I can literally not put anymore in. I see the fluid line just below the basket so that's going to have to do.
Old Oct 8, 2007 | 09:36 PM
Shovelhead Bob's Avatar
Shovelhead Bob
ORIGINAL: gunrunner
ORIGINAL: Shovelhead Bob
With the bike upright and level, the fluid is to be at the BOTTOM of the Clutch Diaphram spring....
Touring bikes take 38-46 oz.... Larger and Different Primary housing...
Softails and Dynas are just about 32....
Don't let anyone with a late model touring bike tell you that you can use 32 and be done with it....
Use the Search Function.... You will see much discussion about this very subject....
Bob, Ive heard you say this before can I ask if this is right then why does the owners manual and the harley shop manual for touring models 02-06 both state 32 ounces, and then do not overfill? I know the 07 up takes more but every 02-06 it says the same thing 32ounces.
And there is a picture with a diagram that shows WHERE the correct level is to be, accompanying the procedures for Primary Fluid Replacement....
I know that the manual refers to 32 oz.... BUT, it also states WHERE the oil level is to be...
Old Oct 8, 2007 | 09:48 PM
Neckball's Avatar
Neckball
Kinda like the engine oil. I've seen discussions on whether to use 3.5 or 4 qts but what the dipstick tells you should be the determining factor.
Trust what Bob tells you, he knows his stuff.
Old Oct 8, 2007 | 09:50 PM
Taterdog's Avatar
Taterdog
Fellas, my 2 cents. Shovelhead Bob is sort of like E. F. Hutton. If he says that's the way it ought to be, I'd recommendwe listen. JMHO.
Old Oct 9, 2007 | 09:32 AM
NICK56's Avatar
NICK56
either will work !
Old Oct 9, 2007 | 09:38 AM
gunrunner's Avatar
gunrunner
ORIGINAL: Mr.Dull
EZ
. You way overfilled it and it can cause a host of problems, but its your's so its your call.
Old Oct 9, 2007 | 09:51 AM
gunrunner's Avatar
gunrunner
ORIGINAL: gunrunner
I guess it's just what ever you want to do, but every time the dealer has serviced any of my bikes (02-06 touring) they have only charged me for 1 qt. of formula +. I garantee you if they had added 4 or more extra ounces I would have been charged for 2 full quarts. And I know Bob knows his stuff, but I can't help to believe if more than 32 ounces was needed to funtion as it is built and functin flawlessly it would not be listed in every shop manual and owners manual for the past many years. I dont think a few extra ounces will hurt it, but show me some proof it helps anything. I will counter what ever is said with the fact that hundreds of thousands of harleys are serviced every year by dealers and Indy's all over the USA and elsewhere with 32 ounces and nothing but good results come from it.
