Is this a Warning or a code
Old Oct 10, 2007 | 07:35 AM
Fla Glide's Avatar
Fla Glide
Default Is this a Warning or a code
Last night when I started up my 04 EG after I hit the starter button she cranked right up and my blinkers flashed 4 times ????? The rest of the night it was fine and no problems this morning.... Is this code for you have a problem.. I know I need to get a service manual as well...
Old Oct 10, 2007 | 11:59 AM
Hardly Dangerous's Avatar
Hardly Dangerous
Default RE: Is this a Warning or a code
Yup. You will need to check if it is current or historic. petemac posted this yesterday:
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Rel
Old Oct 10, 2007 | 06:29 PM
thebiker46's Avatar
thebiker46
Hmmm...I'd better put this info in a folder..really good stuff to know....thanks
Old Oct 10, 2007 | 06:36 PM
choochoo's Avatar
choochoo
do you have the HD security alarm that is built into the turnsignal system?
The ECM doesnot send trouble codes to the turn signals for the engine management system.
It turns on the orange check engine light (engine symbol) to let you know a problem has been detected.
When it does that you then need to follow the directions in the post above on how to pull up the codes.
You actually need two manuals, depending on how much work you or a buddy are going to do or if you take it to an independent.
The bikes Service Manual and the electronics diagnosis manual.
Old Oct 11, 2007 | 03:56 AM
dawg's Avatar
dawg
It's a warning, that means the bike needs to be traded in for a new one. At least that is what you are supposed to tell the wife
Old Oct 11, 2007 | 05:11 AM
tjmac49's Avatar
tjmac49
Hardly Dangerous:
Thanks for taking the time to publish this info here.
51Moe
Sep 7, 2008 11:51 PM
my2004harley
Apr 1, 2008 09:47 AM
crossy
Aug 12, 2007 10:07 PM
Nasty Nightster
General Topics/Tech Tips
Jun 11, 2007 01:39 PM
Saint666
Apr 24, 2007 07:14 PM
