The cambearing on my friends 1997Road King EVOfailed after 30K !
Metal debris damaged cylinderwalls and pistons.
Engine was taken apart and cleaned, cylinders were honed
and oversized (new) pistons installed.
During inspection they found crankshaft was damaged
as well as the cams and oilpump.
Andrew cams were installed with Torrington ballbearings and S&S oilpump.
The hole deal set him back $ 4000, just because the MOCO
didn't fix the bearingproblems.
Warranty ran out, so bad luck for him.
Eighty bucks for an oil change seems a little steep, even if it was all the work that was done. Aside from that, though, at 29.7k (assuming miles) it's time for an oil change anyway, right? So how much do you really think the failed bearing(s?) wrecked you oil/filter? Did they use up the last 2% of its life, maybe?
They put SYN3 in the crank case at about $9 bucks a quart AND charged me labor! I also change my own oil and filter every 5k. Oil usage was not my concern, it was metal debris contaminants that could possibly fail other engine components.
I have an '06 Electra Glide Classic, and mine failed at 25k this year. I now have nearly 29k on it and so far so good, but Im like you , it put doubt in me with the engine.
I dont get it. They are doing A warranty repair . Thats A crock of crap that
you have to pay for the oil and filter ( When it wasnt due )
And then they tag labor on that . What extra work was done , Spin on and off
an oil filter ?
