How Often?
Old Oct 25, 2007 | 03:57 PM
Lost1's Avatar
Lost1
Default RE: How Often?
ORIGINAL: sifularson
ORIGINAL: 24guns
Not trying to hijack your thread, but...
For those going from dino oil to synthetic, is there any concern with the dino oil that is left in the oil pump and the new syn that is being added?
Do they mix ok or should I get one of those total change kit things that runs the oil out of the pump....eeeeek, still scares me.[]
Good question. I'm switching to syn next week.
Synthetics and dino oils are 100% compatible, so you can mix them, change back & forth between dino & syn, etc. all you want and it's completely safe. This is a common question and can be verified at any oil manufacturer's website under their FAQ's.
And don't waste you money on a oil scavenger system- it's a big-money solution for a problem that doesn't exist...
Old Oct 25, 2007 | 04:11 PM
Phrogman's Avatar
Phrogman
Pretty much the same as everyone else. Mobil 1 V-Twin 20/50 in the Engine and Primary, Mobil 1 75/90 in the tranny.
Engine- 5k
Primary/Tranny- 10k
Old Oct 25, 2007 | 04:16 PM
HammerheadC4's Avatar
HammerheadC4
I change then all at the same time. (every 5k or less)
Old Oct 25, 2007 | 04:23 PM
rkcrwlr's Avatar
rkcrwlr
5K (use high quality oil filter)and 10K on the trans/primaryfor me unless the ol'lady takes the notion to boot me out to the garage on a rainyday. Then I change stuff and clean the scoot, ignoring her car.Usually means I get Sunday to myself too - women[>:].
Old Oct 25, 2007 | 04:31 PM
BirchwhiteHD's Avatar
BirchwhiteHD
I change all three holes out between 3,000-4,000 miles ,oils cheap and i probally could go longer in between changes,but i choose to do them all together. im using mobil 1 v-twin 20w50 engine ,mobil 1 75w90 trans, and either HD primary oil or syn 3 in the primary(have some left over after switching to mobil 1) for me it gives me a reason to lay down and look under the bike for any problems ,look things over.
Old Oct 25, 2007 | 04:33 PM
StreetGlide2006's Avatar
StreetGlide2006
I use Red Line products in our bikes. I change motor oil every 5,000 / oil filter every 2,500. Primary and transmission I change at 10,000 or before first ride in the spring.
Ride Safe,
Mike
Old Oct 25, 2007 | 05:46 PM
dog155's Avatar
dog155
Change the motor oil when needed,the other 2 holes in the fall before storage along with the motor oil.
Old Oct 25, 2007 | 05:52 PM
blackrever's Avatar
blackrever
Change all 3 same time at 5k miles.Use Klotz Big twin synthetics
Old Oct 25, 2007 | 06:19 PM
hot77vette's Avatar
hot77vette
change motor,trans.&primary at same time every 3000 with sinc 3 if it needs it or not its my baby .
Old Oct 25, 2007 | 06:30 PM
voodoodrug's Avatar
voodoodrug
5k for eng. 10k prim. around 10k or longer trans.
back-up bike(sporty)once a year and other hole every other year.
