Help Please ( BROKEN)
Old Oct 26, 2007 | 07:45 AM
kpb46's Avatar
kpb46
Default RE: Help Please ( BROKEN)
When I worked for GM, one of my jobs was an engine "repairman". I used to remove broken bolts from engines coming down the line all the time. Hints: When center punching the bolt "TAP" the center punch gently at first. If you hit it hard at first and it is off center , it's a pain to get it back centered. Make sure you use a SHARP bit that is the correct size. If you drill too small, the easy out you will have to use will be too small. You want the biggest easy out possible. If you are drilled on center then drill out the bolt until you get NEAR the threads...not into them.Do not force the drill..let it do the work.I used to use denatured alcohol while trying to remove the bolt. Don't ask me what it does but it works. Go easy when trying to back out the bolt. If it will only go so far then turn it back in and try again. Working it back and forth with the alcohol should do the trick. DO NOT BREAK THE EASY OUT. They are at least as hard as the drill bit an impossible to drill out.
Old Oct 26, 2007 | 07:54 AM
Adam17's Avatar
Adam17
This sounds like great fun...
Old Oct 26, 2007 | 08:02 AM
beary's Avatar
beary
ORIGINAL: Adam17
The drilling worries me around the chrome and the screws are so small.
Tape your chrome.
Beary
Old Oct 26, 2007 | 08:37 AM
rh8234's Avatar
rh8234
If you can find a reverse-twist drill, you just might get lucky and spin the screw out while drilling and avoid having to use the easy-out.
Old Oct 26, 2007 | 10:26 AM
sugarbear's Avatar
sugarbear
ORIGINAL: rh8234
A lot of people make left handed drill bits now a high percentage of the time it will remove the bolt, but I would have an easy out just in case.
Old Oct 26, 2007 | 10:28 AM
sugarbear's Avatar
sugarbear
By the way be sure and use as large an easy out as you can. If you break the easy out in there you have a real problem
Old Oct 26, 2007 | 10:37 AM
05RdKing's Avatar
05RdKing
I would HIGHLY recommend doing it the way kpb46,raftgyde, and a few others heresay- I worked as a mechanic all my life and this works, just take your time, and be careful - do it right the first time, 2nd time usually is fixing a bigger mess
Jimh64
Apr 29, 2019 11:19 PM
Deuceandahalf
Sep 23, 2010 07:36 PM
DR. V-TWIN
Aug 16, 2010 02:48 PM
strtarrow
General Topics/Tech Tips
Dec 14, 2009 03:43 PM
Mandog
Aug 3, 2009 12:09 AM
