Fogged Gas Gauge
Old Oct 26, 2007 | 05:36 AM
RangeRat's Avatar
RangeRat
Default RE: Fogged Gas Gauge
Happens quite often with my '07 FLHR. Of course, I'm direct ocean-frontin FL and PVC rusts here too (J/K... well, sort of J/K). I need to flood the puppy to get salt off and gas guage has drops inside every time,speedo fogs once in a while. They both always dry out though (so far anyway).
Old Oct 26, 2007 | 12:11 PM
madurodave's Avatar
madurodave
ORIGINAL: Geoff
Once in a while thefuel gauge on my '05 Ultra Classicfogs. I can't determine why. My bike is stored in a cool dry garage. It's seen rain only threetimes in 11k miles.I never use a pressure washer, and Idon'tspray the gauge with a water hose when I wash my bike.Any idea why the gauge fogs?
It seems like the majority fog over. Even though you avoid spray/rain, sudden changes in temperatures can make it fog slightly. You will have the same humidity in the gauge as in the surrounding air. If you ride through a colder area, such as a valley, etc., the gauge will fog over for a short time. Once the humidity rebalances for the temperatures or you get into the sun and warmer temps, the fog will dissipate as the water evaporates into the air in the gauge again.
Old Oct 26, 2007 | 12:44 PM
DesertBum's Avatar
DesertBum
Mine fogs up on the gas and tach on my 06 Ultra.
Thought it was and option that we didn't have to pay for
Old Oct 26, 2007 | 01:40 PM
lorenc's Avatar
lorenc
It would seem to me thatI could seal the fuel gauge with silicone or something to not let any air in or out. Wouldnt that stop the "fogging"
Old Oct 26, 2007 | 02:15 PM
Sharknose's Avatar
Sharknose
I don't have the problem, but if I did and it was bothersome I'd probably just shoot the gauge face with a hairdryer.
Old Oct 26, 2007 | 04:18 PM
glens's Avatar
glens
It's really such a minor and relatively short-lived "problem"...
The ultimate solution would be to elaborately seal and fill them with nitrogen!
Old Oct 26, 2007 | 05:50 PM
Taterdog's Avatar
Taterdog
Normal. Only worry if yours doesn't do it.
Old Oct 26, 2007 | 05:58 PM
Retired_Ted's Avatar
Retired_Ted
ORIGINAL: lorenc
Most people don't use the HD fuel gauge anyway - it's notoriously inaccurate. As long as the gauge were filled with dry air, sealing would work. However, a small leak would bring back the same problem and it probably wouldn't dry out due to the faulty seal (Murphy's Law) working only in the venting direction. Speedometers and tachs are also vented - less trouble prone, though. Replacing the gauge with the L.E.D. version is one fix that HD recommends .
Old Oct 26, 2007 | 06:03 PM
v8capt's Avatar
v8capt
the cure for the road king gas gage is : put past silacone on the gage and force it around lens. Wipe it off, no more water or foggy lens.
Capt Bob
Old May 18, 2009 | 09:30 AM
mayfly's Avatar
mayfly
Originally Posted by choochoo
Yep , just another MOCO POS.
They claim "It's Normal!!"
Normally the heat from the light bulb will dry it out after a few minutes riding time.
mine does it too - but now I think that light also burnt out - the only light I have is that annoying bright yellow low fuel idiot light, at night I have no clue how much gas I have left
