Hidden antenna in fairing
Old Oct 26, 2007 | 02:35 PM
Sharknose's Avatar
Sharknose
Default RE: Hidden antenna in fairing
If you don't want the fullsize whip but like listening to the radio you might want to think about a compromise and get a short rubber antenna from Autozone. Mine was $5 and all you do to install it is unscrew the whip antenna and screw the new one on. I usually use the rubber antenna when riding 2 up because the whip hits my wife's helmet.
[IMG]local://upfiles/12883/65CDA9B696BD4B308170768861F520F8.jpg[/IMG]
Old Oct 26, 2007 | 03:25 PM
maineultraclassic's Avatar
maineultraclassic
Very easy and very cheap. I bought mine at AutoZone for $20......it's a powered unit and gives as good reception as the whip antennas or shorty antennas did, and then the install only took about 30 minutes.
Steve
Old Oct 26, 2007 | 03:29 PM
Scootr's Avatar
Scootr
I bought a $10 one from west marine. Same one the boat makers use. Works very well and install is plug and play. I just zip tied it securly around the top of the faring. I can't imagine the more expensive ones work any better. Really cleans up the back of the bike too
Old Oct 26, 2007 | 03:30 PM
mopar7's Avatar
mopar7
Im installing the detachable tour pak and fastback seat. I don't want the antenna in view. I have the short rubber ones on my tour pak now.
Old Oct 26, 2007 | 04:50 PM
Harleypingman's Avatar
Harleypingman
The choices seem to be unpowered (TuneTrapper or equivalents--the marine antenna was a new one for me) and powered (Dakota Digital and private labeled "lookalikes").
There is a wide range of opinions on the effectiveness of all of them. Your best bet is to ask for recommendations from guys that have them where you ride.
Powered antennas (what I have) are easy to install (double sided tape for the small antenna box and mounted on the top of the stereo headunit, plug antenna lead into back of radio, p/u power and ground--the cigarette lighter is what I used).
Old Oct 26, 2007 | 05:40 PM
cybdet's Avatar
cybdet
I cut my stock one down to 15" . Reception works great, no problems at all. Best price: free.
Old Oct 26, 2007 | 07:06 PM
LeadDoggy's Avatar
LeadDoggy
I installed the Dakota Digital on my Classic. Took longer to R&R the outer fairing than it did to install the DD hidden antenna. Works good!
What to do with the treaded stud left behind after you remove the antenna? I can sell you a custom screw on aluminum stud cover for $20
Old Oct 26, 2007 | 07:43 PM
HarlyFan's Avatar
HarlyFan
ORIGINAL: avcaruso
This is where I got mine, simple install and works awesome, even weather band.
http://www.ecshylites.com/page/page/761353.htm
Are you able to get all the weather channels?
Old Oct 27, 2007 | 08:44 AM
billnourse's Avatar
billnourse
My wife has a Marine antenna, and I have Dakota Digital. Can't tell much difference between the two. I have also had a TuneTrapper. Couldn't tell much difference between any of them as far as reception goes. All are adaquate, but none are as good as the whip. I listen to XM most of the tiem anyway, so I will settle for a little less reception for the clean look.
Yes! All of them will recieve the weather channels, just not as good as the whip does.
Bill
Old Oct 27, 2007 | 09:04 AM
cwilks's Avatar
cwilks
ORIGINAL: avcaruso
I use this one also.........works great and easy to install
