Just call AMS and they will tell you what you need and if you ask they will give you the best price. Just google search *AMS harley* or go to www.automotivemachine.com They have everything you need plus the knowledge to go with it. GMR is also an excellent source of Camsand knowledge.
I ordered a complete 26G kit from Wally's Cycle World. It included, cams, gears, bearings, bearing support plate, and cover gasket. At the time, the kit was $535 shipped. I think they are about $569, now. I used the SE adjustable pushrods.
I have also found that Andrews never returns emails but if you call them they will have a tech or sometimes even the owner answer your questions.
Well, I guess they are not alone. Seems a lot of companies set this up as an option on their website, only to ignore the e-mails they get as a result. Pretty annoying for the consumer!
Not quite as expensive as I thought it would be. Thanks for the info, xxx. I'll check Wally's website too.
If you need lifters, check out Crane #10530 lifters for a small block Chevy. They are the exact same lifters as the ones Crane sells for HD's. The only difference is the part number. The difference there is that a set of 4 with the HD number costs upwards of 200 bucks. A set of 16 for a Chevy can be had for about 200 bucks shipped from places like Jegs or Summit. I ordered 16, used 4, and sold the others to people needing them for 50 bucks per 4.
Bro, you are a wealth of information, and since I see you have a 2000 like me, can I bother you for more info? I'm looking at Wally's site for the S&S cam kit, but can't find which one is the 26g gearset. Do you happen to know what p/n you ordered?
Also, since I see you're running a DFO, do you know what model # you have? I've had bad luck with PCIII's, maybe because of the MM EFI. I've got the stage 1 download so I can keep riding around, but if there's something better, I'm interested. Maybe the DFO would work for me.
The last time I looked at Wally's, the Andrews26G kit wasn't listed. I called and asked for it. You will get the cams in an Andrews box and the gears and everything else in a S&S box.
I have the Stealth DFO....just plug and play....no splicing.
