Changing Grips
Old Dec 19, 2005 | 09:10 AM
msbhvn's Avatar
msbhvn
Default Changing Grips
How much trouble is it to change grips from the stock ones and are the hard to align? Dealer or do it your selfer?
Thanks
Old Dec 19, 2005 | 09:14 AM
geno3j's Avatar
geno3j
Default RE: Changing Grips
Do it yourself. Be carful with the right side. If you have access to air just work air nossel into grip area and "poof" off they come. When you go to install the new ones I use a very lil bit of liquid soap about first 1/2 of grip to get them started. They should be off and on in less than 1 hour.
Take your time do it right if you have questions see your service manual or ask a friend.
V/R
Geno
Old Dec 19, 2005 | 09:59 AM
locnkey's Avatar
locnkey
I guess it depends on the bike, I just changed mine on my 05 bagger, the left was hardest because of the dual cable set up. It just took some time and patients, if you have dual cables be careful not to lose the little barrel end on the cable. jack
Old Dec 19, 2005 | 10:00 AM
locnkey's Avatar
locnkey
sorry i meant the RIGHT CABLE.
Old Dec 19, 2005 | 10:27 AM
HDF Tech's Avatar
HDF Tech
It's not hard at all, here's an info post to help you along
https://www.hdforums.com/m_69241/tm.htm
Old Dec 19, 2005 | 10:41 AM
navyman's Avatar
navyman
Just take your time. It is not hard, but the right side can be a bit tricky.
Old Dec 19, 2005 | 08:50 PM
blueknight's Avatar
blueknight
Do yourself, follow directions and have service manual. Take your time and place a sheeet under bike while working on it. Pieces can be seen and picked up easier on sheet. Watch little brass piece on brake lever and watch brake light switch.
Old Dec 19, 2005 | 11:15 PM
pilot1996's Avatar
pilot1996
Piece of cake, follow the manual...use those directions given in the link for pointers.
Mac
Old Dec 19, 2005 | 11:37 PM
mikeisglidn's Avatar
mikeisglidn
a hammer, screwdriver, and a torch may come in handy
Old Dec 20, 2005 | 12:10 AM
SteveO's Avatar
SteveO
Make sure you squeeze the break lever and install a small wedge or popcicle stick to keep it compressed before you start and while you work or you will break the plastic brake light switch when you tighten the screws on the handlebar brackets and pull the brake handle. If it breaks you will loose your brake light function on both the front and rear. It's a plastic piece and what a pain to replace the switch! You have to solder in the new switch and the small wires!
Steve
