Flat tire help
Old Nov 3, 2007 | 02:38 PM
EVOrider's Avatar
EVOrider
Default RE: Flat tire help
800 miles on the tire.....I would probably try plugging it.
Someone else mentioned installing a tube.....that is another feasible idea.
It is getting more and more difficult to find someone that will repair a motorcycle tire.....been lots of lawsuits over the years. Most insurance companies do not allow the dealers to repair tires either....all due to increasingly lawsuits and liabilty. I sure do miss the good ole' days.....any service station use to be glad to help someone out. Not anymore........
Old Nov 3, 2007 | 02:42 PM
NICK56's Avatar
NICK56
PLUG AND RIDE... IVE DONE IT MANY TIMES FOR MANY MILES.. UNLESS THE NAIL IS WAY BIG !
IF TIRE HAS 7 8K MILES ITS JUST ABOUT DUE ANYWAY
Old Nov 3, 2007 | 02:43 PM
anubisss's Avatar
anubisss
I have plugged quite a few motorcycle tires with a plug kit from the auto parts store and have NEVER had a problem. But it is up to you.
Old Nov 3, 2007 | 02:50 PM
MNPGRider's Avatar
MNPGRider
After plugging, and if not installing a tube, I'd add a can of Ride On.
http://www.ride-on.com/prod_mot.asp
Old Nov 3, 2007 | 03:28 PM
eleutheros's Avatar
eleutheros
Read this today, then went into the garage to do some work. I have a nail right in the center of the front tire. The shop wants $250 for a new tire. Can someone please name a good plug kit? I assume I just buy it at the local auto parts store.
Thanks
Old Nov 3, 2007 | 03:52 PM
Trock's Avatar
Trock
I bought a plug-n-go kit. I had a nail in a rear tire with only a few miles on it, I knew there would be times that over the life of that tire I would make some 80+ mph runs so I decided to replace it. But I decided I need a plug kit to get me home in case it happened again. So for practice I used the plug kit on the old tire. The mushroom type plug was pretty impressive, on the inside of the tire the plug looked good enough that I might just might try it if it happened again. It's deffently better than the rope type plugs.
Old Nov 3, 2007 | 04:55 PM
Facetious1's Avatar
Facetious1
OK An update....
I decided to plug... dug out my old tire plug kit..... cleaned the spot to plug... got the plug ready.... and DANG IT ALL TO HECK... My rtubber cement was all dried out.....
SO I go to my mountain bike repair kit...... find a full tube of rubber cement... sweet... untwist the cap.... IT is all dried out also!!!! CRAP!
Well long story short... I bought a whole school issue bottle of the stuff..... Plugged the hole with the kit..... and rode to the auto parts store.... I now carry in my ride along with the issue tool kit:
Plug kit
Bottle of Rubber cement
Needle nosed pliers
12 Volt compressor (it is only about 7 inches by 5 inches and 4-5 inches tall. ---Now I just need to buy the accessory plug kit)
A can of Fix a Flat.
---I also seen these cool chrome air stem caps... had to get those also... but that is besides the point...[8D]
Anyways... did 50 miles today on it... got home... the plug was stable and pressure looked good.
Old Nov 3, 2007 | 08:25 PM
mhuckeba's Avatar
mhuckeba
Never Patch A Tire, It Is Your Life.
[IMG]local://upfiles/41735/46DF41542BAB4AC29D445F75DDB81465.jpg[/IMG]
Old Nov 3, 2007 | 08:42 PM
ridrkg's Avatar
ridrkg
Must be bad 08 luck. I picked up a screw in the rear tire at 1000 miles. I replaced the tire. I ride 2 up a lot and do a lot of rather long trips with lots of luggage. Guess I'm just chicken. I gave the tire to my buddy who hads tube type tires on his laced wheels. If you do decide to plug, the best is the kind that have a patch built on the plug. You have to remove the tire, but the plug with patch is put on from the inside, pretty much eliminating the chance of it coming out. Did this on a Sporty about 3 years ago and it is still working fine. see ya Ken
Old Nov 3, 2007 | 09:02 PM
xxxflhrci's Avatar
xxxflhrci
Check out the back of your Genuine HD Service Manual. It will tell you the procedure for plugging a tire. Dealers don't want to plug a tire to make more $ off of the sale of a new tire.
If I were scared of a plug, I'd tube it and ride on. I definitely would not throw away a tire with only 800 miles on it.
To all of you "replace it" guys: Please send me your nail punctured tires with good tread on them. I will gladly wear them out for you.
