When are injectors too small?
Old Nov 6, 2007 | 10:54 PM
dgriffith's Avatar
dgriffith
Default When are injectors too small?
I have read about a lot of builds this past year or so and I was wondering, At what point does the stock injectors fail to deliver the proper flow? From the time a bike is new, we richen them up to make them run right and then with a little mods.... Or are they over sized to a point that nothing will affect them. Thanks Dan
Old Nov 7, 2007 | 08:08 AM
sugarbear's Avatar
sugarbear
Default RE: When are injectors too small?
I think it has something to do with the duty cycle. If you go with a big build you may want to install a larger intake but I would think the stock injectors would probably work. Maybe someone else can give you a better answer. jmo
Old Nov 7, 2007 | 09:21 AM
stimul8ing guy's Avatar
stimul8ing guy
i'm so tired of hearing bout my small injectors...or are we talkin' bikes here?
Old Nov 7, 2007 | 09:26 AM
sleepneagle's Avatar
sleepneagle
An injector provides a timed flow of fuel based upon the signal sent by the ECM. In the days before EFI, you would have to change jets in the injector based upon temp, humidity and alt. The ECM does all of that for you.
Old Nov 7, 2007 | 01:19 PM
glens's Avatar
glens
I believe there's very good information to be had at http://daytona-twintec.com/ ( search for "injector" within http://daytona-twintec.com/tech_tcfi.html )
Depending on the flow rate of the injector and the amount of fuel needed, the injector could end up being open too long for the optimum time-frame needed.
LVERA
Apr 13, 2018 06:42 PM
hernan
Jun 23, 2015 10:40 PM
jmr1971
Sep 29, 2014 01:37 PM
BWILD
Nov 30, 2008 05:02 PM
jpnelson1978
Jun 4, 2006 11:21 AM
