When should I rebuild
LOL Dude, I have the same bike, and same issue (with oil burning). I posted about it a while back. For the '05 it is an issue with the valve seals. The dealer was swapping them out, if the bike still has warranty left. Mine ended in Sept, and that was when it was becoming an issue. I loose about a quart every 2000, or so. The MoCo allows for a half to one quart every 1000-1500 miles. If you have warranty left, take it in. If not, and the burning oil bothers you, you can have the valve seals replaced. I am sure that is the issue you are having, as it is so similar to what I am experiencing with my '05 rk custom.
As far as a build goes, I am doing a 95" build this winter. I only have 10k on my bike (it was rough getting out this summer), but I am doing it not because the engine needs a rebuild, but because I want some more get up and go. I bought some used jugs and pistons, and am now looking for some cams (and a jet kit). For me, the 88" is okay. Two up, and the bike is a bit sluggish, but not that bad. But, as any type "A" person will tell you, "If a little is good, more is better." LOL You might be just fine with a new cam, which would give you about 4 more HP and Torque. But, with jugs and pistons, you will get a bit more. Then comes head work, and still a little more... it just never ends. LOL Next thing ya know, you will be going to the 120" build so many guys are doing this winter.
If I have learned anything from this forum... it is how to spend my money.
LOL
I have an 05 RG and had the same issue around 15K I had the dealer swap out the valve guide seals and why they had the bike apart under warranty I had them do the 95" Big Bore kit. You save on a lot of labor costbecause they already have the bike tore apart anyway. Just an idea!!
Good Luck!!!!!!!!!
